Activity Forums DaVinci Resolve Feature requests and bugs in 9beta 3
  • Feature requests and bugs in 9beta 3
    Posted by Justin Lovell on September 3, 2012 at 4:50 am
    Is anyone from BM moderating this? (just wondering if this is being read, or if there is a better way to reach out).
    Great Work on the new release.
    Some much needed changes, that shouldn’t be difficult to implement.
    1. Add more speed changing options.
    – in media bin, right click on clip, Video Frame rate : allow custom frame rates. (I do film restoration work and much of it is at 16/18fps or custom frame rates).
    2. Allow custom timeline frame rates
    – Custom, 16/18fps with the ability to render (deliver) downstream at 23.98 or 29.97.
    3. in Timeline allow option for changing speed to be selectable as % or frame rates. ie. used to allow me to change the speed to 18fps, now it only has speed change in 100% and % increments.
    4. Fix speed changing bug
    – clicking on clip to change speed, then redrag the clip to make it the right length, but after extending the length of the clip, it freezes frame at the point where you extend the clip. If you reapply the speed change the clip eliminates the freeze frame and speed changes properly (now that it is extended visually to the right length in the timeline).
    Looking forward to the next release to fix some of these issues!
    Justin Lovell /Assoc. CSC
    cinematographer//
    8/16mm>2K.transfers
    http://www.framediscreet.com
    Gabriele Turchi replied 13 years, 12 months ago 3 Members · 2 Replies
  • Sascha Haber
    September 3, 2012 at 6:27 am
    I agree to all of the above.
    Just inverting the percentage gives a wrong result too.
    A slice of color…
    DaVinci 9b3 OSX 10.8
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    Colorist / Aerial footage nerd
    https://vimeo.com/saschahaber
  • Gabriele Turchi
    September 3, 2012 at 11:53 am
    yep , improving the speed changes is the next big thing i am waiting ,
    sooooo many times i have to leave resolve and pass along shots to others (or i have issue with dynamics applied on shots that have speed changes )
    1)because of the quality of the speed changes in Resolve (only frame duplication )
    2)because the timeline/shot does not ripple when manually apply a speed change
    3)because a dynamic or tracking applied on a shoot on XML that speed change applied on , does not properly translate to the master session (in order to render all the shots nice and clean )
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX470
    24GB RAM
    HP Dreamcolor
    Panasonic 58PF Plasma
    Ultrascope
