Activity Forums Apple Final Cut Pro Legacy Feature Request – Saving Favourite FX to apply group properly
  • Feature Request – Saving Favourite FX to apply group properly
    Posted by Mark Palmos on November 13, 2007 at 6:39 pm
    Just before you shout, “you can, you can!”
    I have applied two boris continuum fx with keyframes and would like to be able to apply that to a number of clips as a single favourite. It is almost there but there is one massive problem.
    When you apply the effect, it remembers the keyframe position in relation to the offset from the file start. In my case, the original source clip I applied the original effect to was 5 mins long, and so now the clips which have had that favourite folder applied to them display the same keyframes, but about 4 minutes past the out point!!!
    So the suggestion is for FCP to be able to choose to apply and scale keyframes OR to apply keyframes starting at IN point OR starting at OUT point. At least this way the keyframes will be in the ballpark!
    TA
    mark.
    Mark Palmos replied 18 years, 10 months ago 3 Members · 4 Replies
  • Nick Meyers
    November 14, 2007 at 11:03 am
    yeah, that[‘s annoying,
    and would be good if they fixed that.
    a workaround is to COPY the original clips and Paste Attributes: Filters.
    that works,
    but you have to keep a dummy clip hanging around.
    cheers,
    nick
  • Mark Palmos
    November 14, 2007 at 1:30 pm
    Hi nick, yep, that works, but then it pastes ALL filters, and so your dummy clip would have to have exactly the same filters, no more. It also applies the filters scaled to the clip size, so if you have a short clip and a very long one, the filters will animate very slowly for the long one, which is usually not what i want.
    thanks mate
    mark.
  • Tom Wolsky
    November 14, 2007 at 1:36 pm
    Uncheck scale attributes to time in the paste attributes dialog.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Mark Palmos
    November 14, 2007 at 2:50 pm
    ooh yeah, that does the trick.
    thanks mark
