Activity Forums Apple Motion Feature Request
  • Feature Request
    Posted by David Mathis on October 26, 2014 at 9:32 pm
    As much as I love using Motion there a couple of things I would like to see in the next update:
    Mask — ability to assign different feather values for x and y, also the ability to have a mask expansion property.
    Transitions — would love to see these as well. Yes, there are plug-ins for this but they should also be native filters as well.
    Video scopes — useful when color correcting an image. Like to have an “objective” insight as to what is going on.
    Simon Ubsdell replied 11 years, 11 months ago 4 Members · 14 Replies
  • 14 Replies
  • Mark Spencer
    October 26, 2014 at 10:08 pm
    Not much we can do about it here but why not tell the folks who make the software:
    https://www.apple.com/feedback/motion.html
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Simon Ubsdell
    October 27, 2014 at 7:42 am
    [David Mathis] “Mask — ability to assign different feather values for x and y, also the ability to have a mask expansion property.”
    This is very easy to achieve already – simply add a Gaussian Blur filter to the mask and you can set different values for horizontal and vertical.
    Simon Ubsdell
    tokyo-uk.com
  • Robin S. kurz
    October 27, 2014 at 8:33 am
    Aside from Mark of course being absolutely right…
    [David Mathis] “Transitions — would love to see these as well.”
    Motion is not an NLE. Transitions don’t make much sense in the context of how it’s meant to be used. Motion is ironically the place where you in fact MAKE transitions. For use in FCP.
    [David Mathis] “Video scopes — useful when color correcting an image.”
    Similar thing. Motion is not a grading app. You would generally do that after importing whatever it is into FCP or send everything to Resolve or the likes when it’s all finished. Both of which of course have scopes.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Simon Ubsdell
    October 27, 2014 at 8:42 am
    [Robin S. Kurz] “Motion is not an NLE. Transitions don’t make much sense in the context of how it’s meant to be used.”
    They clearly make sense to Adobe who give you the option of Transitions in After Effects – where they can be a useful timesaver.
    You’re are right that it’s easy enough to make your own in Motion. But just as the Fade Behavior can be a really quick way of adding fades, a Wipe Behavior would make quite a bit of sense too …
    Simon Ubsdell
    tokyo-uk.com
  • Robin S. kurz
    October 27, 2014 at 9:14 am
    [Simon Ubsdell] “who give you the option of Transitions in After Effects”
    But even those aren’t “transitions” in the classic sense, they’re just called that. They’re simply a pre-fab effect i.e. alpha masks/wipes of sorts, so you’re still doing more compositing than any type of “transitioning”. They don’t even animate themselves. And you could do the exact same in Motion, just maybe not always quite as “one-click”. Be it with 3rd party transitions, masks etc. or anything from the library which is full of stuff to use.
    Since there is no relational connection between layers (such as in an NLE) there’s no way of making transitions in that sense. So you’re back to square one. Animating single layers i.e. compositing. You’re just calling it a different name.
    – RK
  • Simon Ubsdell
    October 27, 2014 at 10:09 am
    [Robin S. Kurz] “But even those aren’t “transitions” in the classic sense, they’re just called that. They’re simply a pre-fab effect i.e. alpha masks/wipes of sorts, so you’re still doing more compositing than any type of “transitioning”.”
    I’m not sure why you would think that a transition is not a compositing operation.
    Except in the fact that they don’t auto-animate, After Effects transitions are clearly transitions in the fullest sense of the term.
    Simon Ubsdell
    tokyo-uk.com
  • Simon Ubsdell
    October 27, 2014 at 10:23 am
    [David Mathis] “Video scopes — useful when color correcting an image. Like to have an “objective” insight as to what is going on.”
    The outstandingly good and useful – and free – PixelConduit plug-in (https://pixelconduit.com/) gives you scopes inside Motion – not the prettiest but adequate as a rough guide.
    (Best of all PixelConduit gives you node-based compositing in Motion … Well worth checking out.)
    Simon Ubsdell
    tokyo-uk.com
  • Robin S. kurz
    October 27, 2014 at 10:29 am
    [Simon Ubsdell] “transitions in the fullest sense of the term.”
    Not in the NLE sense so, no, not in “the fullest sense”. They are effects that can be used as transitions, yes. An NLE (the context/comparison I’m assuming he’s referencing) clearly understands those two things as something entirely different and are also applied and utilised differently. AE simply has a pre-selection of effects that work well as transitions if you like and set them up accordingly.
    But little point in arguing semantics. There are none defined as such in Motion (though there are plenty effects that could serve the exact same purpose) and I don’t see them showing up in that sense any time soon. But who knows. There’s always the aforementioned feedback page.
    And great to know there’s a version of PixelConduit working with the most current versions of Motion and X… I thought it had died with Motion 3 or 4! Nice.
    – RK
  • Simon Ubsdell
    October 27, 2014 at 10:38 am
    [Robin S. Kurz] “Not in the NLE sense so, no, not in “the fullest sense”. They are effects that can be used as transitions, yes. An NLE (the context/comparison I’m assuming he’s referencing) clearly understands those two things as something entirely different and are also applied and utilised differently. AE simply has a pre-selection of effects that work well as transitions if you like and set them up accordingly.
    But little point in arguing semantics”
    Hmmm. OK, let’s just leave it there. I would argue there is no fundamental conceptual difference between an After Effects transition and a typical NLE transition other than the auto-animation option you have mentioned. Your contention that a transition is not a compositing operation is still incorrect.
    [Robin S. Kurz] “There are none defined as such in Motion”
    Not true – there is a built-in transition and I have already mentioned it. It’s the Fade Behavior. As I also pointed out, there is no reason at all why there shouldn’t equally be a Wipe Behavior or a Star Transition Behavior or anything else you care to name …
    But I agree that it’s extremely unlikely that we’ll ever see them implemented in Motion.
    Simon Ubsdell
    tokyo-uk.com
  • Robin S. kurz
    October 27, 2014 at 10:53 am
    [Simon Ubsdell] “OK, let’s just leave it there.”
    But then again… I guess maybe not. 😀
    [Simon Ubsdell] “Your contention that a transition is not a compositing operation is still incorrect.”
    Only that I called it a composition/composing several times and not once did I contend it. It’s a given that a transition is a type of composite.
    [Simon Ubsdell] “there is a built-in transition and I have already mentioned it. It’s the Fade Behavior.”
    Quote “none defined as such“. Even that is called a behaviour, not a transition. One you can obviously use as a transition, sure. Just as you can use AE’s effects as such, as I described. But again, semantics.
    – RK
