Activity › Forums › Adobe After Effects › FEATURE FILM ON HDV
  • FEATURE FILM ON HDV
    Posted by Rajarshi Basu on January 18, 2008 at 4:28 pm
    I am going to be editing a feature lenghth film on Final Cut Pro. HDV 1080p.
    The choice for CC is AFX and Color.
    But I have to give the output on uncompressed QT files. In that case is it better that I do CC in AFX…16bpc, and render out the files from there directly ?
    OR
    Will I render it out from FCP, using Color ?? Does FCP support 16bpc render outs ??
    In any case there will be res loss. I just want to figure out which one will have the minimum loss.
    Raj
    Steve Roberts replied 18 years, 8 months ago 2 Members · 2 Replies
  • Rajarshi Basu
    January 18, 2008 at 5:28 pm
    Hi Dave,
    Thanks for your reply.
    1. Is ProRes 422 automatic ?Or will I get an option in my capture settings ? Because I was considering digitizing native 1080p.
    2. My film has no effects. All I have to do is edit and color correct.
    I think i shall use Color on this one.
    Raj
  • Steve Roberts
    January 18, 2008 at 6:07 pm
    If you’re planning on using Color, ask in a Color forum if there’s anything you should know before proceeding. It’s a quirky app.
