Activity › Forums › Adobe Premiere Pro › Feature Film Audio Sync Advice
  • Feature Film Audio Sync Advice
    Posted by Rajarshi Basu on July 19, 2012 at 7:54 am
    I am editing a feature film, shot using Canon 7D. Now I have already edited the film using camera sound, as I got the location sync sound much later.
    Now, is there a way where I can sync the original clips to the audio and the edited clips in my timeline can update automatically ?
    I would die, if I have to manually edit and rearrange the synced clips over the actual edit all over again !
    Thanks !
    RB
    Igor Jovcevski replied 14 years, 1 month ago 4 Members · 3 Replies
  • Bouke Vahl
    July 19, 2012 at 3:01 pm
    If you have the same amount of tracks, you can paste the new sound in the video, replacing the old sound.
    BWF_QT merge (can be found on my site) can do this for you.
    BUT, be very, very afraid. If you make a small mistake (eg, adding more tracks), chances are your project won’t link to the originals.
    So test before you commit yourself to this!
    There is a tool from Intelligent Assistance, called Sync and Link that should do the trick in a more safe way, and should allow for more channels.
    hth,
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Angelo Lorenzo
    July 19, 2012 at 4:49 pm
    I would suggest looking into Plural Eyes https://www.singularsoftware.com/pluraleyes.html
    It can process two versions of your timeline: one where the sync audio is under your camera audio, and another where your sync audio replaces your camera audio.
    If your edit is locked, I would just grab the demo so you can finish your work. If you edit similar projects often, then I strongly suggest buying it.
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
    RED transcoding, on-set DIT, and RED Epic rental services.
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Igor Jovcevski
    August 28, 2012 at 8:16 am
    you can also try WoOWave WooSync. As someone who was one of the developers of the woosync, I would appreciate your thoughts.
    woowave.com
    thanks
    Igor
