Activity › Forums › Adobe Premiere Pro › Feathering Edges
Feathering Edges
Posted by Aaron Cadieux on February 13, 2008 at 6:25 pmHello,
How do I feather JUST the top and bottom edges of a clip rather than feathering all four edges?
-Aaron
Aaron Cadieux replied 18 years, 7 months ago 5 Members · 7 Replies -
Vince Becquiot
February 13, 2008 at 6:40 pmAre you talking about a full screen clip feathering to black on top, or feathering on a PIP?
Vince
Aaron Cadieux
February 13, 2008 at 6:57 pmBasically, if I crop the top and the bottom of an otherwise full-screen clip, how do I make the crop lines soft and not hard?
Vince Becquiot
February 13, 2008 at 7:03 pmI would create a new color matte (black if you want to feather to black). Place it over your clip, and with the motion settings, zoom it to about 130%, and move up it to the top so that you only see a black bar down to just below the safe margin. Then apply a fast blur to it and play with the blur setting. Do the same for the bottom.
Cheers,
Vince
Steven L. gotz
February 13, 2008 at 7:14 pmOr you can create a track matte with white in the middle, fading to black at the top and bottom.
Steven
Eric Jurgenson
February 13, 2008 at 7:40 pmThis would be really easy if you have After Effects, because AE allows variable H and V softness on masked images. If you have CS2 or CS3, you could use dynamic link, and render (if necessary) in Premiere.
Pentti Kakkori
February 14, 2008 at 8:34 amJust one more: two times video effects>transition>linear wipe. Change the other effects Wipe Angle 180 degrees. Then tweak with both effects’ Transition Completion and Feather adjustments to get the effect you want.
Aaron Cadieux
February 14, 2008 at 2:33 pmIt’s too bad they didn’t think to add a feathering option for the crop tool. That would have made things easier.
