Activity Forums Adobe Premiere Pro Feathering a garbage matte
  • Feathering a garbage matte
    Posted by Mikkell Khan on September 11, 2009 at 5:44 pm
    Hi, I have a sixteen point matte on a duplicate of a piece of video on video 2 over video 1 where the person is too dark and needs to be brightened up without the background (with is the bright blue sky and clouds) to appear washed out.
    I accomplished this with the matte by placing it around the subject and changing the blend mode to linear dodge (add). However, the problem is now the edges of the sixteen point matte are too hard and thus you can blatantly see the separation between the brightened person and the untouched background.
    Is there any way to feather a garbage matte or the edges of the frame to allow there to be a better blending of the duplicate image? Or is there a better way overall to do this?
    Mikkell Khan
    Director
    Diamond Films Ltd. (Trinidad and Tobago)
    John Mullins replied 13 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
  • Eric Jurgenson
    September 11, 2009 at 7:41 pm
    Short answer: After Effects.
  • Mikkell Khan
    September 12, 2009 at 1:29 am
    Lol, and the long answer?
    Mikkell Khan
    Director
  • Mike Velte
    September 12, 2009 at 10:25 am
    Masks in AE can be feathered.
    Track Mattes created in Photoshop can have feathered edges and used in Premiere.
  • Eric Jurgenson
    September 14, 2009 at 12:44 pm
    If you were familiar with After Effects, you would probably know about the softness parameter on the masks. If you aren’t familiar with After Effects, it would be too complicated for me to to explain the whole process. Thus the brief answer. Unfortunately, soft mattes aren’t available in Premiere, unless someone makes a 3rd party plug-in – maybe something like Boris FX.
    But I would highly recommend getting into After Effects (if you aren’t already). It is a great tool for this sort of thing, as well as many other things.
    I should add that although After Effects has variable H and V softness on it’s masks as a whole, Autodesk Combustion has variable softness on each mask line – much nicer.
  • Mikkell Khan
    September 15, 2009 at 6:08 pm
    Thanks Eric. I know some after effects and I’m exploring this possibility. It should most likely work, thanks for the assistance.
    Mikkell Khan
    Director
  • Chris Buttacoli
    September 17, 2009 at 3:50 pm
    There is a way to do this. (But it certainly does not beat using After Effects on an every day basis.)
    Instead of using the Garbage matte, use the titler to make the mask. Go to the frame you want to adjust, and create a new title. Use the pen tool, or the circle tool, to select your area around the people. Make sure the Fill box is checked with solid white.
    Place the title on track 3. Duplicate your footage on track 2, and apply the “Track Matte Key”. Set video 3 as the matte, using matte alpha. Then apply your color correction or levels to adjust the brightness.
    Now add a fast blur to the title, and adjust the amount to create the feathered edge.
    (See why AE is easier. Especially if you need to animate the mask over time.)
  • John Mullins
    October 19, 2012 at 3:20 am
    Genesis! What I love about this technique is that all of the effects are GPU accelerated which on a CUDA card means realtime playback color grading!
    Thank you!
