Activity Forums Apple Final Cut Pro FCX won’t import .mov captured files
  • FCX won’t import .mov captured files
    Posted by Brian Houle on January 8, 2012 at 1:07 am
    Hi folks and Happy New Year to all!
    I’m come across an issue where FCX will not import .mov files captured on my older Macs.
    These files are captured using FCP 5 or 7. Sequence settings are DV NTSC 720×480. I won’t list the audio details as they can be read by my new machine (will explain below).
    What I’m capturing:
    SD camcorder and VHS tapes using a Canopus ADVC300 connected via FW to my macs. I just switch cables to whichever machine I’m using.
    The issue: these captured files can not be read by QT 10.1 nor FCX on my 2010 MP (with Lion). When I try to open them in QT 10.1 or import into FCX, only the audio is present. No video is present. If I open those same files on my 2009 Mac Pro with QT 10.0 (Snow Leopard is the OS), they can be viewed as they should be.
    QT 7 Pro is installed as I do have FCS 3 installed on the same machine. QT 7 Pro can read the same captured files and FCP 7 can also import the file.
    I captured the same tape from within FCX and of course, it works. When I check the info on that file, it is DV/DVCPRO NTSC 720×480
    If I take the files captured from the G5, G4 or 2009 Mac Pro and transcode them using QT using ‘make a Quicktime movie’ and choose DVCPRO as the format – those files work in FCX or can be viewed in QT 10.1
    Support suggested I check the codecs listed in QT 7 on my older machines vs codecs listed in QT 10.1. The only differences are HD codecs listed in the latter.
    I also tried changing my sequence settings in FCP 5 or 7, but there’s no DVPRO option for NTSC – only for PAL. I might try creating a custom capture sequence?
    The only difference is that using Final Cut (any version, but FCX) captures as DV NTSC 720×480 and the new one does DV/DVCPRO. I should also note that I have FCS 3 on both my 2009 and 2010 Mac Pros, as well as FCX. I just tried capturing the same tape using FCP7 on my 2010 Mac Pro and the same things happen – won’t import into FCX and can’t be read by QT 10.1, but can be viewed by QT 7 Pro.
    There ‘ is ‘ a workaround of transcoding the FCS captured files, but as I told Apple pro apps support, in my mind, this is unacceptable – the captured files are just standard def quicktime files. It’s not like I”m asking the G4 or G5 to ingest HD footage. This should be a backwards compatible issue where the latest version of QT should read the captured files. I can’t be profitable waiting for machines to transcode files.
    Apple support of course said that FCX is a new way of thinking and wants the ingestion to occur from within, but these are standard def files and using my older machines as capture decks is critical for me remaining profitable. I need them capturing while I use the new 12 core machine’s horsepower processing other projects for H.264 or DVD. Multi-tasking 🙂
    So, after my long winded run – any suggestions?
    Cheers,
    Brian
    Craig Seeman replied 14 years, 5 months ago 4 Members · 20 Replies
  • 20 Replies
  • Brian Mulligan
    January 8, 2012 at 3:53 am
    No video means its a codec issue. Your fcpx machine doesn’t have the same DV codec as your older machine. There must have been some change inthe QT DV codec from QT 7 to QT 10
    Brian Mulligan
    Senior Editor – Autodesk Smoke
    WTHR-TV Indianapolis,IN, USA
    Twitter: @bkmeditor
  • Brian Houle
    January 8, 2012 at 4:04 am
    Hi Brian,
    Thanks for your response. You’re close – and this is where it’s confusing – I think the new machine does have the right codec. I think it’s FCX which won’t read or use it.
    FCX seems to use DV/DVCPRO NTSC for capturing (or it will import those files as well) whereas FCP 5 and 7 uses DV / NTSC for SD footage.
    I have FCS 3 (FCP7) installed on the same machine and if I use that to capture the tapes, FCP7 reads them no problem, as does QT 7. The more confusing part is that QT 10.0, on my 2009 Mac Pro (with Snow Leopard), can also read the files. I have FCX and FCP7 on that machine as well.
    So it’s QT 10.1 on my 2010 MP with Lion and FCX on either machine which can’t read or use that codec.
    I was hoping to maybe use another sequence setting to capture them?
    Sorry if I wasn’t clear in my original thread. I’ve done so much troubleshooting… 🙂
  • Craig Seeman
    January 8, 2012 at 8:31 pm
    Did you used Software Update on your FCPX machine to ensure you have the updated codecs for it installed? Also withing FCPX choosing Final Cut Pro/Download Additional Content
    would get you those codecs.
    Also here
    https://support.apple.com/kb/DL1396
  • Brian Houle
    January 8, 2012 at 9:10 pm
    Hi Craig,
    Thanks. I did update as soon as it was installed.
    To me, it seems that the DV NTSC 720×480 format wasn’t built in. They went with DV/DVCPRO NTSC 720×480 as their ‘base’ SD format.
    I tried explaining that to the FCX pro apps support as it’s the only difference I’m seeing, but he said as long as the app works, that’s the support they provide. Of course, I politely disagreed with him b/c as far as I can see, it’s not working with their own other apps (being FCP 5 and 7). I don’t expect them to import project files which we know is an issue, but their own basic video format shouldn’t be a roadblock 🙂
    Cheers,
    Brian
  • Craig Seeman
    January 8, 2012 at 10:17 pm
    DV.mov whether from G4, G5, 2009 MacPro, should work, especially if you captured them with FCP legacy.
    If the file works in QT10 Snow Leopard on your 2009 MacPro but not on QT10.1 Lion on your 2010 MacPro, then it may not be the codec you think it is.
    You should download and examine the files in MediaInfo Mac version
    https://mediainfo.sourceforge.net/en/Download
  • Brian Houle
    January 8, 2012 at 11:12 pm
    Thanks Brian – neat app!
    But now I want to shed another tear lol
    I checked one of the original capture files and the format is indeed DV (NTSC) so I checked one of the files I converted in MPEG Streamclip in both mediainfo and QT 10.1
    QT 10.1 = DV/DVCPRO NTSC file
    In Mediainfo = DV (NTSC)! it reads the same as the original file. This adds another layer of confusion.
    I’m with you – these are files created by legacy FCP software so there’s no reason it shouldn’t import. I told the support fellow that too after he told me what I was doing was using ‘older technology’ whereas FCX is a new way to do things. Explained that I wasn’t asking my older machines to rip HD footage or anything. lol These are basic yet important functions for which these machines are perfectly suited. 🙂
    Plus I want the new machine to harness it’s horsepower and not handle menial tasks if I can avoid it – maximize time 🙂
    I sent a detailed feedback page to the FCX team. Not sure what else to do. I truly believe it’s a minor oversight on their part.
    Cheers,
    Brian
  • Craig Seeman
    January 8, 2012 at 11:56 pm
    Doing testing on some of my old files.
    I had no problem importing a DV.mov edit master that was done in FCP 4.5 in 2004
    I had no problem importing a DV.mov file captured in FCP6 in 2007
    I don’t have any DV captured files pre FCP6 since the tapes were camera masters and it was easy to batch capture again in those days.
    Do you know what versions of FCP captured the files you’re having problems with?
  • Brian Houle
    January 9, 2012 at 12:19 am
    Wow! Thanks for taking the extra steps! I appreciate it.
    I’m using FCP 5.1.4 and FCP 7.0.3
    Maybe I should mention that I use a Canopus (or Grass Valley now) ADVC300 connected via FW. I don’t think that would necessarily matter though, but I wanted to mention just in case.
    Interesting that you files worked just fine.
    Also, I captured the same tape on FCP7 on my 2010 Mac Pro and FCX wouldn’t import it either. The support rep had asked if FCS 3 was installed prior to FCX because he was thinking the codecs should be installed. I even installed QT Pro 7 and that didn’t help (aside from being able to see the file using QT 7).
    hmmmm…
    Cheers,
    Brian
  • Craig Seeman
    January 9, 2012 at 12:45 am
    DV tape captured in FCP 7.0.3 should work fine in FCPX.
    Perhaps there was an issue with the capture that FCP7 ignored but FCPX can handle.
    With the ADVC300 you’d do a free running capture so maybe there’s garbage at the head or tail that FCPX isn’t liking. Maybe breaks in the control track from VHS through the ADVC?
    Can you grab a source tape, import into FCP 7.0.3 on the Lion machine with the ADVC and then import the capture file in FCPX on the same machine?
  • Brian Houle
    January 13, 2012 at 2:41 am
    Hi Brian,
    I just wanted to follow up on this thread.
    I’ve had a chat with 2nd level FCX support. I’ve done a series of capture tests and screenshots which I’ve sent to them at their request. They had the same issues and are looking into.
    I’m putting my money on QT 10.1 being the culprit along with FCX. QT 10.0 plays the files perfectly as does FCP 5 and 7. A file captured in FCX reads as DV/DVCPRO NTSC in QT 10.1, but in QT 10.0, it reads as DV NTSC (as does QT 7 Pro) – those files all import into FCP 5 and 7, but not FCX.
    Will keep you posted.
    Cheers,
    Brian
