Activity Forums Apple Final Cut Pro FCX final movie
  • FCX final movie
    Posted by Montaque Pittman on December 9, 2015 at 4:51 pm
    I have created a movie on FCX, and have exported it. After exporting it the actual project was lost. Is there some way that I can find it, or is there a way that final project can be broken back into actual clips?
    Jeremy Garchow replied 10 years, 9 months ago 4 Members · 3 Replies
  • Noah Kadner
    December 10, 2015 at 12:55 am
    Not sure what you mean but if the Project/Library is gone- nothing short of a Christmas miracle is going to restore it. Have you looked into your Backups folder?
    Noah
    FCPWORKS – FCPX Workflow
    FCP eXchange – FCPX Workshops
  • Patrick Donegan
    December 10, 2015 at 1:30 am
    My guess is that it went into the Trash ….
    check there and move it out.
    Otherwise it is very lost and the App called Data Rescue MAY be able to recover it.
    Also – was this on an external drive or the internal drive?
    If it was the internal drive – when you download and install Data Rescue, you will over right
    some of your FCP X library that you want to recover.
  • Jeremy Garchow
    December 10, 2015 at 2:57 am
    Many times I have seen people start with a clip, and choose to “open in timeline”.
    This is the improper way to work, but if you can find that clip that you started with in the browser, right click and choose “open in timeline” you may find your edit.
    Then, select all, copy, make a new Project, and paste the edit into a proper Project.
