Activity Forums Apple Final Cut Pro FCX – chapter markers not on blu ray disc?
  • FCX – chapter markers not on blu ray disc?
    Posted by Brian Houle on January 22, 2012 at 3:57 am
    Hi folks,
    Wow oh wow! 🙂
    I burned my 1st blu ray for a client and omg, does it look stunning!
    But the chapter markers aren’t there.
    Here was my workflow.
    After importing from SD card and camcorder flash HD, i edited my timeline, added chapter markers (now in FCX, they sit right on the footage instead of on the top like FCP7 right?
    I went to share – blu ray
    made the title change, choose a disc template then went to advanced and chose send to compressor.
    I did that instead of to ‘burn’ on the bottom right because I use a Matrox CompressHD card for h.264 compression. It’s fairly fast – just about a 1:1 compression time
    Compression 4 came up and I replaced the h.264 compressor preset with a matrox one (same specs) then submitted.
    it burned just fine after a few hours – I thought it was going to crash as my 1st 2 attempts with compressor failed for whatever reason.
    Popped the disc into my home theatre and voila, it’s perfect except for no chapter markers – which is a massive drawback for me. I mean, clients were used to fast forwarding with VHS, but no reason at all to do that with BR!
    Has anyone had issues with the CompressHD not importing chapter markers? Or maybe I placed them incorrectly? (screenshot attached). I thought about exporting a self-contained prores file before dropping into Compressor4, but I don’t think that would work with doing the menus? Or maybe I need Adobe Encore for full authoring – I really like the ability to have chapters for my clients as I arrange their DVDs (home movies) into chapters based on their content. Ie. this BR has a trip to Mexico, a birthday party, cottage time etc..etc..
    Cheers,
    Brian
    Brian Houle replied 14 years, 4 months ago 5 Members · 13 Replies
  • 13 Replies
  • Brian Houle
    January 22, 2012 at 4:33 am
    Ok..so maybe i’m about to answer my own question, but I found this on Apple’s forums:
    Totally shocked if this is true so if anyone could confirm before I try again it would be appreciated.
    Chapters export just fine to Apple devices like the iPad in Compressor 4. You just have to make sure you make the markers Chapter markers and not Compression which is the default. I just did a test from a FCPX project: Share>Send to Compressor. I selected the Apple Device 5MB preset and added chapter markers manually. It’s an extra step but it really doesn’t take that long. The chapters showed up fine on my iPad, in Quicktime X, and in VLC.
    To speed things up, I added the markers in FCPX using the shortcut M (hit M again to edit the marker). After adding the markers I opened the Timeline Index where you can see all your markers. From there I took the timecode for each one, put it in the Compressor timecode, and hit enter. Then hit M to add the marker, and then Command-E to edit the marker. Unless you have tons of chapter markers it’s not going to add much time to your workflow. “
  • Brian Houle
    January 23, 2012 at 12:11 am
    Just to report for those of you who weren’t aware, but my last post was correct – you need to add chapters in Compressor 4.
    Completely idiotic imho. What a waste of time (even though it doesn’t take long – that’s not the point).
    I find the disc authoring in compressor to be completely basic at best. It does work, but ick…
    I don’t understand why they couldn’t adapt DVD studio pro for blu ray!?! 🙁
    Now i”m looking at Adobe Encore or Toast which is unfortunate for the Encore as you can’t buy it seperately.
    Am I pouting too much or rightfully upset at the change in workflow?
    lol
    Cheers,
    Brian
  • Gerry Fraiberg
    January 23, 2012 at 12:43 am
    The markers in Final Cut Pro X are not Chapter markers. Chapter markers have to be added in Compressor 4.
    From FCP X Help:
    Markers are reference points you can place within clips to locate, identify, and annotate specific frames. In editing, markers are particularly useful for synchronizing two or more clips at a specific point. For example, you can use a marker to label the frame where a door slams and then snap a sound effect to that marker. You can use markers to flag a specific location in a clip with editing notes or other descriptive information. You can also use markers for task management. Markers are classified as informational (blue markers), to-do items (red markers), and completed to-do items (green markers).
    From Compressor 4 Help:
    Chapter markers: Chapter markers allow easy access to index points throughout a DVD, QuickTime movie, or podcast. QuickTime Player can interpret any text track containing time stamps as a chapter track. Chapter markers can also have artwork and a URL assigned to them that appear when playing a podcast.
    These markers appear as purple in the Preview window timeline.
  • Brian Houle
    January 23, 2012 at 2:19 am
    Thanks Gerry. I appreciate the information.
    Then I guess I shall proceed with that workflow although it will remain curious to me why they changed that from FCP7 🙁
    My edits are generally basic in nature so adding chapter markers in the timeline worked perfectly.
    Cheers,
    Brian
  • Gerry Fraiberg
    January 23, 2012 at 2:58 am
    It’s anybody’s guess, however dropping DVD Studio Pro is a strong hint as to the direction Apple is taking with FCP X. You could always try to “Provide Feedback” to Apple from within FCP X.
  • Andreas Kiel
    January 23, 2012 at 1:11 pm
    As said above, all the marker types we were used to are gone with X.
    You can use the digitalRebellion tool https://www.digitalrebellion.com/promedia/ to get chapters into an exported movie within seconds.
    – Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Brian Houle
    January 23, 2012 at 2:29 pm
    Thanks Andreas.
    Does this work using the share – DVD or Blu Ray option? I ask because that process seems to be ‘locked’ in a sense. Ie. we don’t have access to the files before they are burned.
    Gerry, thanks – I definitely have 🙂 lol
    Cheers,
    Brian
  • Andreas Kiel
    January 23, 2012 at 4:56 pm
    No there is no chance at the moment to create(and use) chapter markers inside FCPX. 🙁
    – Andreas
    Spherico
  • Andreas Kiel
    January 24, 2012 at 5:38 pm
    Here some crazy thoughts how to bring back chapter markers.
    Take a simple (one line) title, add it to the timeline where you want, shorten it, add your chapter name and apply a unique role – like ‘Chapter’. You can setup one and from there copy paste and change the chapter name, or use the find/replace title text and the end.
    Now export as XML and export the movie. Don’t forget get do disable the ‘Chapter’ role on export. During editing you just can topgle visibility.
    Then use my XTE to extract the titles. Once they are loaded, you can use the popup to see all the ‘Chapter’ titles and save them to a chapter list text file. The quick hack I did for the app saves both an STL and a chapter file.
    In Compressor use the Import ‘Chapter List…’ to import your chapter files.
    Though it sounds a bit complicated, in my oppionion it’s easier than with markers – both in FCPX and Compressor. In X you can have the old fashioned overlay and move ‘chapter titles’ easily.
    -Andreas
    Download (3.8 MB) for free:
    https://www.spherico.com/filmtools/TitleExchange/XTE%20Install.dmg
    Spherico
  • Kevin Rockwood
    February 17, 2012 at 10:31 pm
    I just created this app to convert markers from a FCPX xml file to a .txt file that you can import into compressor. It’s not ideal, but it should make the process easier until apple adds the functionality. Let me know if you have any issues with it.
    https://github.com/rockwood/fcpx-Marker-Converter
