Activity › Forums › Apple Final Cut Pro Legacy › FCS2 logging HDV footage question..a touch long, sorry
  • FCS2 logging HDV footage question..a touch long, sorry
    Posted by David Mcgiffert on February 8, 2008 at 5:35 pm
    I import footage into FCS2 from a Canon XH-A1.
    I put in a reel number and a short description and have to use the ‘capture now’ setting.
    The clips come into the logging bin with the description and then a
    number, i.e. Reel 06,(description), untitled 2-33.
    Here is my question;
    I naturally want to describe the clip in more specific’s than how
    it comes into the bin.
    Eace time I rename a clip, do I have to go to the Modify Menu/Rename/rename file to match clip, for each changed clip description?
    Or,
    is there a better way?
    Thank you,
    David
    David Mcgiffert replied 18 years, 7 months ago 2 Members · 2 Replies
  • Andrew Commiskey
    February 8, 2008 at 6:19 pm
    You can make all your changes and then select all the clips and change them in one shot.
    Drew
    Chaos is the beginning of everything.
  • David Mcgiffert
    February 8, 2008 at 6:26 pm
    No way! Really?
    Whew…
    I have about 25 hours to log.
    (talk about Chaos…)
    Thank you,
    David
