Activity Forums Apple Final Cut Pro Legacy FCS2 and Lion
  • Posted by Drake Hale on July 20, 2011 at 5:57 pm
    I realize this has been asked before but with Lion’s offical release today does anybody have any info on the functionality of Final Cut Studio 2 with Lion? The reason I’m so concerned is that my copy is from an education license from my college but I do no have access to the disks any longer. Any brave souls try this yet?
    Scott Sheriff replied 15 years, 2 months ago 4 Members · 3 Replies
  • Michael Gissing
    July 21, 2011 at 12:17 am
    Why would you bother?
  • Bill Kelly
    July 21, 2011 at 2:49 am
    I’ve read that FCS2 should run fine under Lion. The key is you have to have it installed BEFORE you upgrade. Apparently FCS uses some installer called Rosetta that won’t work with Lion, but if FCS is already installed on the hard drive when you upgrade then there’s no need to run the installation package with Rosetta.
    I’m hoping this is true because I run FCS2 as well. I’m going to wait on Lion for a few months anyway til most of the bugs get worked out. By then we should know if FCS2 works with Lion or not.
  • Scott Sheriff
    July 21, 2011 at 5:12 am
    A popular gearhead expression, that seems to apply here:
    “If it ain’t broke, don’t screw with it.”
    Scott Sheriff
    Director
    https://www.sstdigitalmedia.com
    “If you think it’s expensive to hire a professional to do the job, wait until you hire an amateur.” —Red Adair
    Where were you on 6/21?
