Activity › Forums › Apple Final Cut Pro Legacy › FCS2 720p 59.94 DF ???
Posted by Sam Zimman on May 21, 2007 at 6:07 pmDoes Final Cut Studio 2 let you do 720p 59.94 Drop-Frame?
Walter Biscardi replied 19 years, 3 months ago 3 Members · 3 Replies -
Walter Biscardi
May 21, 2007 at 6:08 pm[Sam Zimman] “Does Final Cut Studio 2 let you do 720p 59.94 Drop-Frame?”
What I was told at NAB was that it will NOT do this right out of the box, but it will be added later. This is something I’ve been waiting on for two years now.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Shane Ross
May 21, 2007 at 7:24 pm[Dave LaRonde] “It would be interesting to know how you’ve compensated for the accumulated 1 2/3 second error in a half-hour show for the past two years.”
Planning. You figure out what the timing needs to be in NDF for it to properly work out to the required time in DF. As simple as putting SLUG into a DF timeline until you get the right time, then copy and pasting that into an NDF timeline and seeing where it ends time wise.
Pain, but the workaround I use.
Shane
Littlefrog Post
http://www.lfhd.net -
Walter Biscardi
May 21, 2007 at 7:28 pm[Shane Ross] “Planning. You figure out what the timing needs to be in NDF for it to properly work out to the required time in DF. As simple as putting SLUG into a DF timeline until you get the right time, then copy and pasting that into an NDF timeline and seeing where it ends time wise.”
that’s a clever idea. You can also copy and paste your shows from an NDF to DF timeline to get the accurate timing there.
