Activity › Forums › Apple Final Cut Pro Legacy › [FCS 6.0 -FCP 7.0] AVCHD, yes or NOT?
Posted by Duca Simone luchini on October 20, 2009 at 9:10 amHallo,
I’m in total confusion about AVCHD files and FCP…I have a Macbookpro (intel) and FCP 6.0 (but I’m going to buy FCP7.0)
I’ve decided to buy a AG-HMC151E but I’ve discovered that there are a lot of problem between FCP and AVCHD files…
I don’t want to convert all file registered in AVCHD… and I won’t buy this camcorder if I can’t find a solution with FCP (ver.6 o 7 ).
I readed about FCS 2 Upgrade and FCE but I’d like to know if there is a same solution for FCS3 cause this is a NEW version!
So, how can we TODAY, NOW, work with AVCHD files directily in FCP 6 or better, FCS7 ?
THX a lot!Bye
Rafael Amador replied 16 years, 9 months ago 4 Members · 9 Replies -
Tom Wolsky
October 20, 2009 at 11:05 amUpdate to 6.0.6 and can work with AVCHD today.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Duca Simone luchini
October 20, 2009 at 11:14 amThanks Tom,
but… what about FCP 7.0? I’m going to buy new version (FCS3) but if doesn’t work with AVCHD… I stay with my FCP 6.0… you know?THX!
Rafael Amador
October 20, 2009 at 11:20 amMauritio,
FC 6.0.0 is one of the buggiest ever FC versions.
one week after the release Apple was posting FC 6.0.1 (Pro Application 2.008…)
Very buggy too.
I haven’t updated to FC 6.0.6.
I’m in Fc 6.0.5 and works well.
rafael -
Duca Simone luchini
October 20, 2009 at 11:29 amOk, very well
i’v understood but … what about new FC version FCP 7.0 ?
I know it can manage only AVCintra… -
Rafael Amador
October 20, 2009 at 12:06 pmFC is supporting ACHD and AVC-Intra since FC 6.0.2 (FC release notes).
In FC 7 I guess they have extended the support for AVC-Intra, but they didn’t drop the support to AVCHD:
https://www.apple.com/finalcutstudio/finalcutpro/broad-format-support.html
Rafael -
Mike Raff
October 20, 2009 at 2:39 pmSomeone will correct me if I’m mistaken, but I believe FCP has to convert AVCHD to ProRes in order to edit the files (this occurs during Log & Transfer).
So while it is true that Final Cut can edit AVCHD files, it cannot edit them natively.
Since you said you do not wish to convert all your AVCHD files, I thought I should point this out.
Hope that helps.
Mike Raff
Richmond, VA -
Tom Wolsky
October 20, 2009 at 2:51 pmIt does have to be converted, so basically yes, but you can specify what you want it converted to, Apple Intermediate Codec, ProRes, in v7 you can go to ProResLT, which I think works very well for this type of media. You can always render composite segments in full ProRes.
All the best,
Tom
Duca Simone luchini
October 20, 2009 at 4:15 pmSo well,
for summarize :
FCP 6.0.6 can manage AVCHD files importing in FCP by “Log & Transfer” command.
So you can NOT import in FCP pro and drop in Timeline and edit AVCHD natively files but you have to convert these in Pro res file and than edit.
But which kind of sequence setting I’ve to set ti utilize this ProRes files resulting from conversition? -
Rafael Amador
October 21, 2009 at 1:19 am[Maurito Zarate] “But which kind of sequence setting I’ve to set ti utilize this ProRes files resulting from conversition? “
A sequence matching those Prores files.
rafael
