Activity Forums Apple Final Cut Pro Legacy FCS 6 24p Capture Settings Help
  • FCS 6 24p Capture Settings Help
    Posted by Katie Mims on November 7, 2007 at 4:41 pm
    Hi Everyone,
    I have the Sony HVR-V1U, and I did a search on the forum to see if I could find out what capture settings work with the footage from my camera and FCS6, and didn’t find much.
    My question is, what capture settings work in this newer version? Can it work with the 24p footage from this camera?
    Can I use the HDV 1080i60 or 1080p24 easy setup?
    Or do I need to capture it and then reverse telecine it in CinemaTools? If so, what is the best codec to capture in?
    Any help would be appreciated! Trying to use FCP 5 with the footage from my camera was a nightmare. I’m really hoping it’s simpler in this version!
    Sony HVR-V1U
    FCS 6
    MacBook Pro
    2.2 Intel Core 2 Duo
    2 GB SDRAM
    Katie Mims replied 18 years, 9 months ago 1 Member · 1 Reply
  • Katie Mims
    November 7, 2007 at 10:23 pm
    As I said in my post, I’ve already searched through all the forums. Everything that I found is either dealing with other V1U issues unrelated to capture settings, and the rest are either unanswered questions or outdated information from FCP 5.
    Thanks for trying to help though.
