Activity Forums Apple Final Cut Pro Legacy FCS 2 Crash on Render
  • FCS 2 Crash on Render
    Posted by Alex D’eath on November 17, 2008 at 4:12 pm
    I have posted this same question on the apple board but I would like to get as many eyes on this as possible.
    I would like to get some opinions before I blow up my machine and reinstall everything. 3 weeks ago I made several changes to my system. Since then I have had an issue with FCP locking up on render and then have to shut down the tower with the power button as the render hangs the machine up and will not let it shut down. I was running FCS 6.0.2 and OSX 10.5.4 and whatever version of QT came before 7.5.5.
    I have Adobe CS3, Noise industries and Gen Arts loaded on my machine. I upgraded Noise Industries and added their Yanotype application at that time as well. This required me to update the system. While this was going on we imported some AE files from a new editor into our system for a show he was off-lining for us. I know there were issues with past updates playing nice with NI plugins. I want to know if anyone can point me in the right direction.
    My first thought is to reformat the system drive and restore back to before all the update were run. Then slowly bring the system forward until the problem occurs. The only major issue will be the need to upgrade back to 6.0.4 as we have worked on multiple projects that are now 6.0.4.
    Please help.
    Thanks Alex
    Mike Halper replied 17 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Harry Bromley-davenport
    November 18, 2008 at 10:20 am
    Mr D’Eath,
    I am a fellow sufferer from FCP crashes while rendering.
    I’ve done everything. EVERYTHING … You name it. Including erasing all drives and reinstalling System and FCS from scratch — and I’m not mentioning Disk Warrior, trashing prefs and all that stuff.
    Anything more complicated than a 3 minute render of a simple effect causes a crash, so I have learned – over the past two years, that I must baby sit my renders and do them in tiny portions while intermittently saving.
    I’m on a Mac Octo with all the latest FCS software and a well maintained system, by the way.
    The ONLY way I have found to render any lengthy section, or an entire timeline, without crashing, I have found is to set the “autorender” to (say) “after 10 mins of inactivity” in Prefs and then to go away and PRAY.
    For reasons that I cannot understand, the autorender generally does not crash the machine. But if I initiate a render without interrupting and saving all the time, I get a crash.
    If you have ANY IDEAS AT ALL, HOWEVER IDIOTIC which might assist me in curing this disgusting situation, please contact me.
    From a fellow sufferer.
    Harry
  • Alex D’eath
    November 18, 2008 at 1:36 pm
    Hard Luck Harry,
    Have you tried eliminating your media files. I have heard that having a single corrupt file can wreak havoc on your system. I am restoring my system back to when it was operating properly. If I still have problems after that I will begin removing media from my most recent project and reimporting until the problem repeats and fix that media.
    Alex D’Eath
    alex@spacecityfilms.com
    Operations Manager
    Space City Films, Inc
    Above & Beyond…..
    November 19, 2008 at 2:41 am
    Hey, thanks for the reply, Alex.
    Maybe it is indeed some errant media file causing my problems, but I have had the same crashing problem now for 2 years while cutting 3 feature length projects.
    In any case, tomorrow I will do some experiments with taking say, a 10 minute segment of unrendered material and, piece by piece, removing and then reinserting shots.
    The problem is that, when I get to the end of this ghastly experiment and find that I am still crashing, how do I know that it was not MORE THAN ONE shot which is causing it?
    Thanks for the suggestion. Any further ideas accepted.
    I long to be able to set FCP to render, go out and take my dogs for a walk for half and hour and feel confident that, when I return, I will not be faced with “FCP has quit unexpectedly”
    All the best with your own problem and thank you for the input.
    Harry
  • C david Miller
    November 19, 2008 at 3:35 am
    Alex,
    Try turning off your ethernet or wireless connection in the Network Preferences and see if it still crashes
    C. David Miller
    CN8/Comcast Network Television
    Central Pennsylvania Region
    1050 East King Street
    York, PA 17403
    717-771-2623
    November 19, 2008 at 4:07 am
    Mr Miller,
    Is this suggestion you kindly make based on a cure that you yourself experienced? If not, may I ask what the theory behind the suggestion is?
    With thanks for the reply to the thread.
    Harry.
  • C david Miller
    November 19, 2008 at 4:51 am
    Harry,
    If you’d like to drop me your email address, I will pass on the reasoning behind my madness. I can send screenshots over the forum. My email address is David_Miller9@cable.comcast.com
    Dave
    C. David Miller
    York, PA 17403
    717-771-2623
  • Mike Halper
    January 10, 2009 at 8:24 am
    For the past 1.5 years or so I’ve had a similar problem. I cut a feature on FCP 5.1.4 (or whatever the laast FCP5 version was) and everything with rendering worked great. I even color corrected in FCP using Magic Bullet Look Suite and never had any problems with rendering taking over 24 hours. FCP6 came out and we eventually decided to go back to the feature to make some changes and were never able to render more than 5-10 minutes of footage or more than an hour of rendering time. This same issue occurred with several smaller projects afterwards, even with reinstalling the OS and all software from scratch, running the system lean with no other software, and on 3 different systems. I even went as far as removing all filters from the project and not using any third party plugins with no luck.
    The only way I’ve been able to render is by actually doing an Export / Quicktime movie.
    I’ve read here and on other forums of many people also having this issue. Now I have sent a bug report to Apple about this a few times, and even wrote email a few months back to Steve Jobs about how infuriated I was that they weren’t fixing this problem. I even provided links to forum threads as evidence of the issue.
    So a few weeks ago 6.0.5 comes out. As usual I hoped that Apple finally fixed this problem (I’m convinced it’s a bug like the Quicktime gamma issue), but wasn’t about to waste time trying until I heard from others. Around the same time I needed to reinstall the OS and set the system up fresh again. I started work on a project and forgot to turn off the auto-render feature (the auto-render always crashed for me) and left the room for a few hours. I came back and discovered that it had started rendering and… was actually still rendering! In over a year I’ve never been able to render that much at one time. I cancelled the render because I didn’t need to render yet, and haven’t bothered to trying rendering again.
    Has anyone else had successes with rendering in 6.0.5? Has Apple finally fixed the problem?
    _______________________________________________
    Mike
