Activity Forums Apple Final Cut Pro FCPX…Share…DVD: No Longer Per Rec. 601?
  • FCPX…Share…DVD: No Longer Per Rec. 601?
    Posted by John A. mozzer on December 18, 2013 at 9:11 am
    FCPX…Share…DVD no longer does the right thing with my NTSC-DV material, though it used to. During playback, only 704 x 480 should display out of the 720 x 480 pixel array, per Rec. 601. I assume some sort of metadata should tell this to the player. But when I play the resulting DVD with both DVD Player and VLC, the full 720 pixels, including transition samples on the left and right, are squeezed into the 4:3 display.
    Has anyone else experienced this?
    John A. mozzer replied 12 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
