Activity Forums Apple Final Cut Pro FCPX won’t render video filmed at different frame rates….
  • FCPX won’t render video filmed at different frame rates….
    Posted by Jack Niedenthal on November 19, 2011 at 3:09 am
    I am using a Panasonic HPX 170 with a P2 card.
    I recently filmed a video at 720/24pN. I changed the frame rate of one scene to capture at 48 fps so it could be in slow motion. At first when I went to import into FCPX it would import everything at 24pN but not the scene filmed at 48fps.
    I did manage do eventually get this done by creating a new Event, then importing that single 48 fps clip, but now it doesn’t render, it just comes out as a jumble of weird colors while the rest of the scene filmed in 24p looks fine… ?? On timeline it reads 100% rendered…
    Jack Niedenthal
    Microwave Films of the Marshall Islands
    http://www.microwavefilms.org
    iMac i7 using Lion 10.7.x, HPX 170 using only one 64GB card
    I live on an island in the middle of the Pacific, YOU are my only resource.
    Jack Niedenthal replied 14 years, 9 months ago 3 Members · 8 Replies
  • 8 Replies
  • Oliver Peters
    November 19, 2011 at 3:39 am
    I don’t know why, but if you still have FCS/FCP7, then place it on a new timeline in FCP7, render and export a self-contained QT at 24fps. Then import that into FCP X and replace the other clip. This should get you through the immediate issue.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Jeremy Garchow
    November 19, 2011 at 3:58 am
    Was it in 24pN mode? If so, the clip should come Inc conformed, or did you record 48 over 60?
  • Jack Niedenthal
    November 19, 2011 at 4:12 am
    I was in FILM CAM mode then just switched the frame rate from default (shooting at 24pN) and put the frame rate at 48 and then shot the scene.
    Jack Niedenthal
  • Jeremy Garchow
    November 19, 2011 at 3:35 pm
    If you shot 48 frames at 24pN, then the files should come in as slow motion as they are conformed in camera.
    Uncheck the option to “remove pulldown” on the import options screen and reimport. That should help you.
    Jeremy
  • Jack Niedenthal
    November 20, 2011 at 12:32 am
    Jeremy, thanks for responding but the “remove pulldown option” was off… Any other ideas?
    Jack Niedenthal
  • Jack Niedenthal
    November 20, 2011 at 1:17 am
    Not sure what I did, but it now seems to be working. One of those things I guess.
    Jack Niedenthal
  • Jeremy Garchow
    November 20, 2011 at 6:39 pm
    [Jack Niedenthal] “Not sure what I did, but it now seems to be working. One of those things I guess.”
    Did you reimport the footage or did it just “start working”?
  • Jack Niedenthal
    November 21, 2011 at 5:25 am
    Actually, I completely re-filmed the scene at 48 fps and it imported just fine. I may have done something weird with that one setting. I also filmed at 60 fps and it also worked. It was just that one particular scene that wouldn’t work right…
    One thing I did do is I created a separate event for each of the slow motion scenes when I imported them, then I just dragged them onto the timeline with the footage I had done at 24pN. They played and exported just fine.
    Jack Niedenthal
