Activity › Forums › Apple Final Cut Pro › Fcpx viewer distorted and discolored
  • Oliver Peters
    December 11, 2014 at 12:43 am
    Huh? Of the two images you posted, the FCP X viewer image looks correct. The master file displayed via QT Player looks wrong. This appears to be the opposite of your description.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Ronnie Gilmer
    December 11, 2014 at 12:47 am
    It’s like it on both it’s harder to see it in the picture
  • Bret Williams
    December 11, 2014 at 1:00 am
    If it’s on both why is is an FCPX problem?
  • Ronnie Gilmer
    December 11, 2014 at 2:05 am
    I agree I’ve never had it I’m asking around in general
  • Bret Williams
    December 11, 2014 at 2:49 am
    You haven’t actually asked anything. You provided a screen shot of some bad footage. Yep looks bad. What’d you do to it?
  • Ronnie Gilmer
    December 11, 2014 at 3:17 am
    The footage isn’t bad I’ve opened it in iMovie , and QuickTime and it was fine. But when imported into fcpx this happends.
  • Oliver Peters
    December 11, 2014 at 1:19 pm
    [Ronnie Gilmer] “and QuickTime and it was fine.”
    But your screen grab shows it in Quicktime and it is messed up. The image has some sort of checkerboard pattern all over it. How is this good?
    – Oliver
    Orlando, FL
  • Ronnie Gilmer
    December 11, 2014 at 1:26 pm
    The screen shot shows the master file after it was saved. fCPx saves the file with the discoloration. If I instead of importing to fcpx and I just open in QuickTime straight from the camera the footage is fine. The footage only becomes messed up when imported into final cut
  • Oliver Peters
    December 11, 2014 at 1:28 pm
    [Ronnie Gilmer] “The screen shot shows the master file after it was saved.”
    Please post a screen grab of the original file prior to FCP X. And also some technical specs, like codec, frame size, etc. What happens when you use a different NLE, like FCP 7 or Premiere Pro?
    – Oliver
    Orlando, FL
