Activity › Forums › Apple Final Cut Pro › FCPX Viewer different than Resolve & Vimeo
Posted by Matt Harris on September 9, 2013 at 1:03 amThe image in FCPx is totally different then other applications and online with vimeo. My 24″ LED cinema display has been calibrated with Spyder Pro. Any ideas why its inaccurate?
Randy Larcombe replied 11 years, 1 month ago 7 Members · 12 Replies -
Bill Davis
September 9, 2013 at 3:03 amWhat do the scopes in your X interface say?
There’s no way to do critical judgements on displays, calibrated or not, that come anywhere close to looking at your signal properties via test equipment.
Monitors lie. Even so called “calibrated” monitors react to elements like room lighting and environmental issues such as reflected colors, etc. etc.
Scopes don’t lie.
(Well, good ones don’t anyway.)
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
Matt Harris
September 9, 2013 at 6:20 am -
James Cude
September 9, 2013 at 7:20 amColor calibration is an art unto itself- learn video scopes well and rely on those. Having a proper broadcast monitor is also key. And just FYI- the Spyder is for print work, not video.
Oliver Peters
September 9, 2013 at 12:08 pmNo computer monitor is accurate for video and all applications compensate in different ways. The only way to judge accuracy is a high-quality, calibrated video monitor and external scopes connected to a hardware I/O, like a BMD Decklink.
Oliver
Orlando, FL
http://www.oliverpeters.com -
James Cude
September 9, 2013 at 5:41 pmDoes it look the same in QuickTime Player X? That’s supposed to match FCP X.
Matt Harris
September 9, 2013 at 6:36 pmYes. FCPX and Quicktime look different than everything else, so I cant grade accurately even for my own computer screen.
Jakub Vomacka
September 9, 2013 at 10:19 pmI had a similar problem on my setup. It was caused by calibration profile from X-rite device. The problem lied in version of profile, which was default at version 4 but fcpx liked version 2.
It may or may not help you, maybe you dont have such controls in your software for spyder. What you can verify is your profile though. Choose one of the stock ones for your monitor and than check the appropriate applications. If this color shift vanishes, it was the color profile. If not, there must be something else going on.
Breanna Molloy
October 6, 2014 at 5:12 amI’ve been having the same issue. The image looks great in FCP and in Quicktime, but it looks dark and contrasty when its played on a Flash player like Mpeg Streamclip or Vimeo.
I don’t know why the players are so different, but it would be nice if I could calibrate my viewer in FCP for Flash, since Vimeo is my video’s final destination. Let me know if you’ve had any luck with this. 🙂
Matt Harris
October 6, 2014 at 9:20 pmHey Breanna, I’ve learned that Apple just does this when watching with Quicktime or in FCPX. I can play the same file with FLC and it looks different. I think it best no to grade in FCPX because of this. When something is uploaded into vimeo it generally will look closer to Davinci Resolve than FCPX. I can even watch the same vimeo file in Firefox and then in Safari and they will look different. I’f anything is compressed then it has to be decoded in some way, and I think that process probably varies a lot.
Randy Larcombe
August 12, 2015 at 9:32 amHey Matt, Did you ever sort out this issue? I am having the same problem. Cheers Randy
