Activity Forums Apple Final Cut Pro FCPX v.10.4 “Color wheels” defect
  • FCPX v.10.4 “Color wheels” defect
    Posted by Frank Valtellina on December 27, 2017 at 8:17 pm
    Hi, using “color wheels” new feature I’ve found an issue in the brightness control for the highlights, midtones and shadows. For example if you change the brightness value of shadows the highlights value change too and it should not. It doesn’t happen with “color board” exposure value if you change the shadows value the highlights level don’t change at all. Is it a bug? Apple knows?
    Dave Jenkins replied 8 years, 8 months ago 5 Members · 6 Replies
  • Jeff Kirkland
    December 28, 2017 at 8:14 am
    Can’t say I’ve seen it. There’s little bit of crossover as you’d expect but the colour board and the colour wheels function pretty much the same way here.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Frank Valtellina
    December 28, 2017 at 8:27 am
    oops… Sorry Jeff, I’ve pushed the wrong button. ☹
    Create with photoshop a png gradient from white to black, open the waveform and make some test
  • Frank Valtellina
    December 28, 2017 at 8:35 am
    I’ve found out another little bug… if you try to insert a numeric value in brightness and saturation controls of “color wheels”… You can do but it doesn’t work.
  • Mark Smith
    December 28, 2017 at 12:46 pm
    I’ve just used color wheels and checked the highlight control on a clip I was grading. There is some crossover when manipulation the highlight control but it is no different than color curves or color board on my system. From what I see the grading effect behaves as I would expect.
  • Oliver Peters
    January 1, 2018 at 7:27 pm
    You might want to bounce over to the debate forum and look at this thread.
    https://forums.creativecow.net/thread/335/99802
    – Oliver
    Oliver Peters – oliverpeters.com
  • Dave Jenkins
    January 3, 2018 at 4:19 am
    I just tested it and the wheels don’t work the same as the Board or the Curves. The highlights pull up the shadows and vice versa.
    Dajen Productions, Santa Barbara, CA
    Mac Pro 3.5MHz 6-Core Late 2013
    FCP X
