Activity Forums Apple Final Cut Pro Legacy FCPX – Transform not working as expected
  • FCPX – Transform not working as expected
    Posted by Tony Barone on December 5, 2013 at 2:22 pm
    I have 2 video tracks
    Top video track I created keyframes on Position & Scale going from 100% size, Position X:0 Y:0 at Timeframe 1:00
    Timeframe 3:00 – Scale: 50% X:485 Y:270 Keyframes
    Basically creating a PIP effect of the video shrinking into the corner.
    I want to reverse the effect after another 5 seconds or so, but when I create new keyframes of its current position, everything in between gets completely messed up! The video moves completely off the screen.
    At no point have I created any keyframes other than the ones I listed above.
    Any ideas?
    Mark Suszko replied 12 years, 9 months ago 3 Members · 3 Replies
  • Dino Vince
    December 5, 2013 at 4:59 pm
    sounds like you need another set of keyframes of the PIP scale and position, for as long as you want to hold it there. So A position, B position, B position, A position. Does that do the trick?
  • Tony Barone
    December 5, 2013 at 5:09 pm
    Thanks for your reply.
    Your suggestion is exactly the way I have it setup, and I would have expected it to work, but it doesn’t.
    In my setup: Position A – Position B —5 sec— Position B – Position A
    During the —5 sec— part, there is a LOT of motion that was never keyframed in. I have tried several times… deleting all keyframes, starting from scratch, etc.
  • Mark Suszko
    December 5, 2013 at 6:01 pm
    Did you try asking this in the FCPX forum?
