Activity Forums Creative Community Conversations FCPX Transcoding
  • Posted by Sean Davison on March 14, 2013 at 12:05 pm
    Hi All,
    Im a pro Editor (20yrs) FCP and Avid.
    Thought I’d give FCPX a go. Digitised a load of (tape based) DV footage using iMovie and then imported the resulting quick times into FCPX (Didn’t optimise which was my big mistake). So far so good. struggled through a 30 minute edit (over 1000 dv clips) and then wanted to export to Resolve to grade. Problem is Resolve doesn’t seem to play nice with the native .dv clips that iMovie created. What I need to do used to be called a media manage while transcoding media – to create a new sequence that refs the new prores files. Then export an xml to resolve and away we go.
    I didn’t optimize the clips on import and they all have a .dv suffix so I guess I meed to convert them. Can I do this from within FCPX (I see nice words like transcode but they don’t seem to do anything) I do not want to export a flattened quicktime into resolve – I want the clips individual to round trip back to fcp x. I cant work out how to do this. If I use compressor to batch convert the files the surely fcp x wont like the new suffix when it comes to reconnecting.
    Any advice?
    Sean
    Life on the Bleedin’ Cutting Edge….
    http://www.twotallmen.co.uk
    James Ewart replied 13 years, 6 months ago 10 Members · 22 Replies
  • 22 Replies
  • Shawn Strong
    March 14, 2013 at 12:26 pm
    ProRes
  • Craig Seeman
    March 14, 2013 at 1:51 pm
    I haven’t dealt with .dv recently but if FCPX sees it as a format that can be optimized, you can optimize at any point in the editing process to ProRes.
  • Matt Trubac
    March 14, 2013 at 2:04 pm
    I haven’t used .dv in FCPX, but did you take a look inside your event folder in the finder?
    Go to:
    Your Volume > Final Cut Events > Your Event Name > Transcoded Media > High Quality Media
    It’s possible FCPX optimized your media and you didn’t even realize while it happened in the background.
  • Sean Davison
    March 14, 2013 at 2:16 pm
    No it hasn’t – everything is still dv and I’m not getting an option to transcode on import. I wonder if it’s the same issue that Resolve seems to be having…
    Thanks for the advice Shawn
  • Oliver Peters
    March 14, 2013 at 2:42 pm
    I don’t know specifically about .dv, but FCP X does not optimize media it thinks is already optimized. That might be the case here. Normally, you should be able to highlight clips and then transcode from the menu. If that’s not available, then FCP X won’t let you force a transcode. You probably need to transcode externally using Compressor or MPEG Streamclip. In general, I haven’t been too happy with how FCP X deals with SD sources using DV codecs (MOV or DV). Transcoding to ProRes will help a lot.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Oliver Peters
    March 14, 2013 at 2:48 pm
    PS: Let me ask – what do you mean Resolve doesn’t play nice with .dv? Do you mean the video doesn’t show up or that the real-time performance is poor? If the latter, then that’s probably normal for Resolve. It’s one of the worst graders for real-time playback (with lots of corrections added) unless you have multiple GPU cards. However, that doesn’t matter, because you will render out of Resolve anyway before round-tripping back into FCP X. That render can be set to ProRes.
    OTOH, if you don’t see video at all in Resolve, then that means Resolve doesn’t support the codec or wrapper.
    – Oliver
    Orlando, FL
  • Oliver Peters
    March 14, 2013 at 2:51 pm
    PPS: Yet another option for you. Use Xto7 to go from FCP X to FCP 7. Media manage in FCP 7 and then roundtrip to Resolve from FCP 7. You can roundtrip back to FCP X from Resolve.
    – Oliver
    Orlando, FL
  • Sean Davison
    March 14, 2013 at 5:58 pm
    Thanks for all that. Using FCP7 seems like a cop out as Im doing this to test FCPX workflows to see how capable it is.
    Resolve doesn’t like the DV format and neither does FCPX – I Transcoded using compressor and FCPX was happy but wouldnt see the audio because I left audio pass thru on.
    Ive got the files in now (all 1500 of em). Ill be Interested to see how resolve deals with them. I was hoping to be able to get them into Logic pro for a bit of a dub but for some strange reason that isn’t possible and Apple are still buggering around with LogicX. Automatic Duck has ceased to work with FCPX so…
    My initial opinion is that FCPX isn’t quite as Robust as Apple seem to claim.
    Annoying isn’t it?
    Thanks for the suggestions
  • Craig Seeman
    March 14, 2013 at 6:12 pm
    Just some odd “peanut gallery” thoughts.
    You can ingest DV tapes straight into FCPX so I can’t see why you went the iMovie route.
    That said, FCPX has an import iMovie feature as well so I’m wondering if it might have handled that better than using the .dv files directly.
  • Oliver Peters
    March 14, 2013 at 6:19 pm
    [Sean Davison] “My initial opinion is that FCPX isn’t quite as Robust as Apple seem to claim.”
    Actually it is quite robust, all things considered. It just isn’t as full-featured as you might need at this point. You say using FCP 7 is a cop-out, yet every complex project I’ve worked on to date has required diving into FCP7/FCS for some function. The days of a single NLE that fits all functions are over in my opinion.
    There is no connection to Logic from FCP X at this point in time. Your DV audio is likely 32kHz, which is the reason for the audio compatibility problems.
    – Oliver
    Orlando, FL
Page 1 of 3
