Activity › Forums › Apple Final Cut Pro › FCPX to Premiere Pro
Posted by Guy Crossman on June 13, 2025 at 3:23 pmHanding over an FCPX project to an editor on Premiere Pro, anyone know a good way to do it?
Thanks Guy
Eric Santiago replied 1 year, 1 month ago 5 Members · 6 Replies -
Jeremy Garchow
June 13, 2025 at 3:56 pmIf you are trying to translate a whole library, XtoCC on the App Store is your best bet. Not a perfect translation but it will get you pretty close.
Devrim Akteke
June 13, 2025 at 7:33 pmExactly, XtoCC is a good tool to convert from FCPX to Premiere.
Another way is exporting an XML and using Davinci Resolve to import and exporting AAF from Resolve, but this is not as easy as XtoCC :), but it works.
Eric Santiago
June 16, 2025 at 2:21 pmYep best tool out there is XtoCC as well as other apps from dev.
Nina Tailor
July 25, 2025 at 12:45 pmIs there a way of bringing the keywords and markers from FCP to DeVincie?
Eric Santiago
July 28, 2025 at 1:31 pmGoogle:
While there isn’t a direct way to import Final Cut Pro X (FCPX) keywords and favorites into DaVinci Resolve, you can export metadata as a CSV file from FCPX and then import it into Resolve’s Media Pool. This method allows you to leverage keywords and other metadata for organization within Resolve.
Eric Santiago
July 28, 2025 at 1:46 pmAs far as Markers, I can only suggest using the timeline export to xml.
