Activity Forums Creative Community Conversations FCPX to Motion App
  • Steve Connor
    February 22, 2012 at 2:19 pm
    Just about to give it a try, I’m in the middle of a project with some Motion work in!
    Steve Connor
    “FCPX Agitator”
    Adrenalin Television
  • Walter Soyka
    February 22, 2012 at 3:18 pm
    This is a step in the right direction, so many thanks and cheers to developer Alex King.
    However, it’s still a long way off from the straightforward round-trip workflow of the classic “Send to Motion” command.
    From FCPX Send To Motion App [link]:
    Just export your project as .fcpxml (File > Export XML), drag it onto the dock icon, select the clip you’d like to export, and it’ll create and open a new Motion project, setup with the right length, clip, and frame rate. It’s not perfect, but it saves a lot of time setting up projects and copying information by hand.
    And here’s a comment from the developer in the original linked article:
    “What I tend to do is render a movie, copy the old clip in FCPX, drop on the new clip to replace and audition, and then paste effects from the old clip, so you get your audio/etc. changes back.”
    Walter Soyka
  • Mark Dobson
    February 22, 2012 at 3:32 pm
    Well I’ve tried this app out unsuccessfully twice now and it’s all a bit of a faff.
    Very similar to the workflow for using pluraleyes but at this stage without the result.
    So I’ve exported the XML, dropped it on the App, selected a clip. It does open up in Motion but at this stage only as a still image.
    I’ll have a play with it later again but probably just continue using my own clunky workaround of exporting a file and opening it up in Motion etc etc
    But it is definitely a step in the right direction.
