Activity Forums Avid Media Composer FCPX to MC
  • FCPX to MC
    Posted by Nick Hrycyk on July 2, 2017 at 10:11 am
    I’ve been asked to ‘finish’ an hour doc once the rough cut (director) is done. Besides the fact I would only have 5 days to tweek, color, mix and fix the whole thing. Rough cut being done in FCPX, what would I be getting into trying to get something usable in MC from FCPX. XML? Probably no AAF? I have never touched FCPX. Thoughts/ideas very much appreciated!
    Nick Hrycyk
    Bluefish Post
    Hugh Hartford replied 8 years, 2 months ago 5 Members · 6 Replies
  • Oliver Peters
    July 2, 2017 at 12:25 pm
    FCPX only outputs FCPXML lists, which are unique. You will need other apps to convert these lists to something else. Your best bet is to use Resolve. It can read FCPXML and output AAF. So you can use Resolve to roundtrip the material into MC. If the rough cut is simple enough and the media is proper (valid TC, no dupe names) it should work.
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Michael Phillips
    July 2, 2017 at 1:29 pm
    Or once in Resolve, just finish there?
    Michael
  • Glenn Sakatch
    July 3, 2017 at 2:00 pm
    Remember, you might be able to get a list out of Resolve to Avid to build the sequence, but you will not be getting all the bin information and organization, so you will pretty much have to rebuild that yourself. Might be time for a crash course in fcpx if you only have 5 days.
    Once the edit is locked, then move it over to resolve for a finish…or resolve to avid for a finish.
    Glenn
  • Oliver Peters
    July 3, 2017 at 3:53 pm
    [Glenn Sakatch] “but you will not be getting all the bin information and organization”
    Yep. Roundtrips through Resolve are typically only good for sequence translation, not whole projects.
    – Oliver
    Orlando, FL
  • Nick Hrycyk
    July 5, 2017 at 10:58 am
    Thanks for the suggestions. I am going to experiment with the FCPX-Resolve route, however I am going to pass on this particular gig. 5 days for what they want plus when I asked about the audio mix the answer was “We’re not looking for a full mix, just some stock music where needed!” Whole thing feels like trouble waiting to happen! Just because you can do something doesn’t mean you should!
    Nick Hrycyk
    Bluefish Post
  • Hugh Hartford
    June 21, 2018 at 10:28 am
    Did you find a good workflow for this? We’re migrating a whole feature doc cut in FCPX to AVID. We have all the rushes as quicktime pro res. I’d prefer not to go via the AAF route unless you can add handles when exporting from resolve that include the entire original clip.
    Any suggestions?
