Activity › Forums › Apple Final Cut Pro › FCPX Text Drop Shadow picking up some of the color of the text.
  • FCPX Text Drop Shadow picking up some of the color of the text.
    Posted by Jory Levine on June 14, 2018 at 3:29 pm
    After adding basic text, I chose a color for it and then put in a drop shadow with the default black color
    for the shadow ( as most would use). I’m noticing that there is a cast on the drop shadow of the blue
    color I and using on the lettering. WTF? If I want to color my drop shadow I can do that. I don’t need FCPX
    making decisions for me. Anyone notice this happening or know how to get rid of it?
    Jory Levine replied 8 years, 3 months ago 3 Members · 6 Replies
  • Jared Ewing
    June 14, 2018 at 5:14 pm
    Hi Jory, I just tried to recreate this but I don’t see the cast.
    For me, the default drop shadow opacity is 75%. Could this be causing the slight color cast you’re seeing?
    Can you upload a screenshot?
    – Jared
  • Andreas Kiel
    June 14, 2018 at 11:23 pm
    Tried here – no cast. How did you measure the color?
    Spherico
    https://www.spherico.com/filmtools
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
  • Jory Levine
    June 15, 2018 at 3:03 pm
    Here you go. As you can see, a blue cast to the drop shadow from the light blue lettering.
    Opacity is 100% so it’s not coming from anything behind the letters.
  • Jory Levine
    June 15, 2018 at 3:42 pm
    OK, I just figured it out.
    When you’re selecting a color for title lettering on the Color Board
    if you use Master, it also colors the drop shadow regardless of
    the color you select in the Drop Shadow area.
    The same it true of Shadows on the Color Board.
    Midtones seems to have no effect on the drop shadow and doesn’t
    change the lettering color either.
    If you use the Highlights to color the lettering, it changes the color
    but leaves the drop shadow at the color selected in the Drop Shadow effect
    panel.
    Case Solved
  • Andreas Kiel
    June 15, 2018 at 3:51 pm
    [Jory Levine] When you’re selecting a color for title lettering on the Color Board
    You know where to set font color?
    And you know when to use the Color Board?
    Spherico
  • Jory Levine
    June 15, 2018 at 4:46 pm
    Just found the title color options under FACE.
    I was using Color Board – Master which is why I had the drop shadow issue
    although I did discover title color change is achievable
    without affecting the drop shadow in Color Board by only
    using the Highlights adjustment.
    All good now.
