Activity Forums Apple Final Cut Pro fcpx stabilizing workflow
  • fcpx stabilizing workflow
    Posted by Jason Leue on October 11, 2011 at 6:06 pm
    With fcp 7 the best workflow was to re-render out the footage you were actually using in your cut and then use smooth cam other wise it would analyze the whole clip in the bin.
    Is this the same in fcpx?
    Does fcpx analyze the whole clip or just what I’m using in my timeline when I click stabilize in the inspector window?
    I know it analyzes the whole clip if I select analyze on import, that’s why I don’t use it. Why would I want to analyze the whole clip unless I have too, which is why I’m asking.
    Sorry if this has been covered, couldn’t find info on this anywhere.
    Jason
    Chris Northcross replied 14 years, 9 months ago 3 Members · 3 Replies
  • Roger Bolton
    October 12, 2011 at 2:14 am
    Turning on stabilize in the inspector only analyzes the portion in use in the timeline.
    CoreMelt V2 plugins
  • Jason Leue
    October 13, 2011 at 10:34 pm
    hey there you go.
    one up for the X
    takes 10,000 hours to master something
  • Chris Northcross
    November 18, 2011 at 11:31 am
    Rock on! Didn’t realize this and spent a while stabilizing the entire clip (time waster!) Thanks for this.
    “Whether you think you can or can’t, you’re right.”
