Activity › Forums › Apple Final Cut Pro › fcpx — replacement for matrox mxo2 mini max
  • fcpx — replacement for matrox mxo2 mini max
    Posted by Robert Shanks on October 21, 2016 at 12:10 am
    will someone please recommend a replacement since matrox no longer supports video/audio breakout boxes to monitor audio video ???
    ROBERT SHANKS
    Bret Williams replied 9 years, 11 months ago 6 Members · 8 Replies
  • 8 Replies
  • Noah Kadner
    October 21, 2016 at 1:47 am
    Tons of Blackmagic and AJA gear that would do what the Matrox did and more. Depends on budget and which connections you want to use.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Robert Shanks
    October 21, 2016 at 1:59 am
    Tks Noah Ill check them out. I am looking for just hdmi and analog analog audio via thunderbolt.
    ROBERT SHANKS
  • Noah Kadner
    October 21, 2016 at 3:55 am
    Yep that would be anything from a Blackmagic Intensity on up.
    Noah
  • Craig Seeman
    October 21, 2016 at 1:22 pm
    Do you still have a need for analog out for monitoring?
    Otherwise you might look at Blackmagic Ultrastudio MiniMonitor. Thunderbolt to HDMI or SDI out.
    Perhaps the Ultrastudio Express Thunderbolt to HDMI or analog breakout would be better for you.
  • Jeremy Garchow
    October 21, 2016 at 3:39 pm
    I have both Blackmagic and AJA boxes for FCPX. I would stick with AJA with FCPX. The TTAP work every well, and is cost effective, but does not have analog audio out.
    Jeremy
  • Bret Williams
    October 23, 2016 at 2:10 am
    I’m guessing your BMD doesn’t work with the new 8.x software drivers either. Mine went about 3 seconds without crashing. I didn’t waste any more time and plugged my t-tap right back in.
    _______________________________________________________________________
    https://BretFX.com Plugins & Templates for FCP X Editors & Motion Graphics Artists
  • Paul Golden
    October 24, 2016 at 2:18 am
    The Ultra Studio Mini Monitor goes HDMI or SDI with embedded audio out. As does the T-Tap. But then it’s usually easy to pull analog audio as a loop through from the audio out of most monitors.
  • Bret Williams
    October 24, 2016 at 12:48 pm
    That’s what I’m doing with the T-tap. I pull audio from the iMac most of the time as that’s what I’m watching. But I also have the speakers hooked up to the audio out of the Flanders client monitor so I can switch to that audio as well, just by switching audio out in the iMac. There is a delay of a couple frames between the two. Basically what you see/hear coming from the t-tap or ultra studio will be a couple frames behind what you see/hear on the computer viewer.
