Activity › Forums › Apple Final Cut Pro › FCPX, RED and Logic Pro
  • FCPX, RED and Logic Pro
    Posted by Eric Santiago on October 12, 2018 at 10:56 pm
    Trying to send audio via FCP XML to Logic Pro.
    The project has RED files but the videos have been stripped and only WAV files are intact.
    However, some of the files are using the AUDIO SYNC technique and some might have been mixed up with RED audio.
    The Unsupported Movie Format error pops up but I can’t seem to find the suspect clip in Logic and its stripped from the FCPX Project.
    The is that it’s asking me to convert the movie to QuickTime 7. Not gonna happen 😛
    The other issue is when saving the Logic file you get two options.
    Package or Folders.
    Well just like the last issue I had with Consolidating in FCPX when using Folders, Logic creates a folder as well as same data in the Package. This doubles up the data for some weird reason.
    And I tested the Logic doc with the folder hidden and it wont work.
    So with Folder as the option, it seems to double up files.
    Just curious as to why I’ll just keep using Package.
    Eric Santiago replied 7 years, 11 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    October 14, 2018 at 2:12 pm
    Are these separate system wavs, or wavs from R3D?
    If R3D, I’d suggest sending an AAF to Logic Pro with X2Pro.
  • Eric Santiago
    October 15, 2018 at 9:28 pm
    [Jeremy Garchow] “Are these separate system wavs, or wavs from R3D?
    Separate audio nothing from the R3Ds as far as audio goes.
    I got lucky this time around but yes I will give X2Pro a look at in the future.
    I haven’t used that plugin since the last few FCPX upgrades.
    Need to see if I still have a version that works.
  • Jeremy Garchow
    October 15, 2018 at 10:35 pm
    You can simply update from the App Store. Should be good!
  • Eric Santiago
    October 16, 2018 at 12:44 pm
    [Jeremy Garchow] “You can simply update from the App Store. Should be good!”
    Thanks Jeremy!
