Activity Forums Apple Final Cut Pro FCPX putting gaps between images.
  • FCPX putting gaps between images.
    Posted by Kristin Kirby on November 26, 2019 at 7:30 pm
    Hi there:
    Sometimes my timeline clips won’t lock together – there’s a space between them that I can’t get to go away of about 1 frame. It’s happening right now with stills, which are powerpoints changed into .jpgs. If I try to move the images closer together, one of them moves up to the secondary timeline above it. I can’t get the gap to go away. Sometimes it happens with video clips as well. If any one can tell me what’s going on, I’d love it! Here’s a screen shot, zoomed in:
    Bret Williams replied 6 years, 10 months ago 3 Members · 4 Replies
  • Oliver Peters
    November 26, 2019 at 7:44 pm
    I believe this is an intermittent bug that goes back to the beginning. At least something like this has been reported before in the earliest versions. The gap may actually be less than a whole frame. Or it may simply be the way it is represented in the timeline. Do an export and see if these gaps are really there and if the images are actually next to each other at the cut.
    – Oliver
    Oliver Peters – oliverpeters.com
  • Kristin Kirby
    November 27, 2019 at 12:28 am
    Hi Oliver,
    When I export, and I look at the video I can’t see anything. The gap is so small that you can’t see anything anyway. So how do I tell if there really is a gap? I guess it probably doesn’t matter if you can’t see it anyway, but I’ve had the experience where there’s a little flash if you look closely.
    Kristin
  • Oliver Peters
    November 27, 2019 at 12:50 am
    I’m not sure if this is the exact same issue, but look through the replies in this thread.
    https://discussions.apple.com/thread/6475932
    If you Google “FCPX back frames between clips” you’ll see a ton of variations to this issue going back to 2011.
    – Oliver
  • Bret Williams
    November 28, 2019 at 5:31 pm
    Not to state the obvious, but you do have snapping turned on when you try and move it back with the mouse? Or, just try nudging it with the “,” and “.” keys?
    ______________________________________________________
    FCPX TUTORIALS – https://www.youtube.com/BretFX
