Activity › Forums › Apple Final Cut Pro › FCPX projects and TM backups
  • FCPX projects and TM backups
    Posted by Fabrizio D’agnano on December 30, 2012 at 10:08 pm
    Hello.
    I switched to FCPX a couple of months ago and just finished my first two “real” projects I’m now going to deliver and archive. I was so busy learning the new tools and workflows that I overlooked what I consider one of the most crucial points: the project and media backup. I’ve learnt there’s only one copy of the project that gets updated as the edit goes on, and that a 15 min earlier than the current copy is kept. As for the media, I save both a camera archive for each AVCHD card and a copy of the imported non-optimized files (in my line of work I end up with hundreds of clips only a dozen or so are actually used from) on a safe RAID NAS. So I guess I should be able to rebuild the media in case my MP internal RAID fails. But what if the project file gets corrupted? I am running TM backups of the internal RAID array excluding the Events folder, but I have seen the projects folder that is included also contains the rendered media folder, that can be big. I’ve seen all projects have the same name, so is there a way to safely keep a quickly usable copy of a project other than manually building a folder structure with the real project name and date and a CurrentVersion.fcpproject file inside?
    Thank you
    Fabrizio D’Agnano
    Rome, Italy
    Fabrizio D’agnano replied 13 years, 9 months ago 2 Members · 2 Replies
  • Tom Wolsky
    December 30, 2012 at 10:20 pm
    Get ProVersioner from Digital Rebellion. It provides autosave vault functions for FCP and other applications.
    All the best,
    Tom
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
    “Complete Training for FCPX” from Class on Demand
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Fabrizio D’agnano
    December 30, 2012 at 10:35 pm
    Thank you Tom.
    Your help is precious as always. I just downloaded the trial and it seems the right tool.
    Fabrizio D’Agnano
    Rome, Italy
