Activity › Forums › Apple Final Cut Pro › FCPX Plugins
FCPX Plugins
Posted by Hashim Otaifa on October 10, 2011 at 8:31 amHi,
I wonder where shall i put the downloaded extra plugins to the FCPX?
Simon Ubsdell replied 14 years, 11 months ago 4 Members · 6 Replies -
James Cude
October 10, 2011 at 4:16 pmMost plugins you’d buy for FCPX come with an installer or instructions- start there.
Tony Brittan
October 10, 2011 at 8:44 pmOP is probably talking about the ones posted here for free. If he reads the instructions provided by Simon and the others here for theirs, he find the answer he seeks!
Hashim Otaifa
October 10, 2011 at 9:41 pmYes exactly i mean the ones posted here alike this one for example: https://forums.creativecow.net/thread/344/3047 by simon.
There is no instruction on how you put in to FCPX.
Tony Brittan
October 10, 2011 at 9:50 pmHis older ones have instructions. Try this one:
https://mobi.creativecow.net/thread/344/3123
And it’s a great one too! This is posted using my iPhone so I don’t know how it will show on a computer but it should work.
Simon Ubsdell
October 11, 2011 at 10:12 am[Hashim Otaifa] “I wonder where shall i put the downloaded extra plugins to the FCPX?”
Here are some installation instructions (courtesy of Brendan Gibbons):
Drop the folder inside this zip into the following directory:
User/Movies / Motion Templates / Effects
Important:
For those of you that don’t have Motion 5 installed you need to create the correct folder structure inside of your User/Movies folder.
Firstly create a folder called Motion Templates
Inside that make the following folders:
Compositions
Effects
Generators
Titles
TransitionsAfter you have done that, each folder needs a extension added to it for it to work correctly.
Do a Command + I (Get Info) on each folder and add “.localized” (without quotes) to the end of the folder name in the info window
Motion Templates.localized
Simon Ubsdell
Director/Editor/Writer
http://www.tokyo-uk.com
