Activity Forums Creative Community Conversations FCPX output to XDR display
  • FCPX output to XDR display
    Posted by Tom Sefton on February 18, 2020 at 10:59 pm
    Does anyone know if fcpx has a limit for the resolution that can be sent to the XDR display? We have an LG 5K display and an XDR display connected to a 16 core Mac Pro, with a pro vega II gpu and a vega VII. The vega VII isn’t directly connected to any monitors as it only had display port or hdmi outputs, but resolve and fcpx can see it.
    When I open an 8K project in fcpx and bring 8K footage in, and enable the AV output on fcpx, the resolution that fcpx tries to push to the xdr display is stated as 4096 x 2160 @60Hz. If the xdr display is 6K resolution isn’t there a way of outputting 6K to the display from fcpx?
    Co-owner at Pollen Studio
    http://www.pollenstudio.co.uk
    Oliver Peters replied 6 years, 6 months ago 4 Members · 6 Replies
  • Jeremy Garchow
    February 18, 2020 at 11:14 pm
    [Tom Sefton] “If the xdr display is 6K resolution isn’t there a way of outputting 6K to the display from fcpx?”
    What res does it say in Sys Pref > Displays?
    Do you have to drop the refresh rate to get 6k?
  • Eric Santiago
    February 19, 2020 at 3:33 pm
    Curious as to what you are sending to the XDR.
    Just as a monitor feed or the GUI?
  • Tom Sefton
    February 19, 2020 at 7:01 pm
    Checked again today.
    In sys prefs/displays, it shows the LG at 5K and the XDR at 6K.
    In fcpx, when you select the xdr display as program out, it says inside some brackets that are none changeable, 4096×2160@59.94Hz
    My project settings in fcpx are 7680×4320@24p
    The display looks absolutely incredible, and the performance with red media and prores 8K files is nothing short of staggering.
  • Jeremy Garchow
    February 19, 2020 at 9:48 pm
    [Tom Sefton] “In fcpx, when you select the xdr display as program out, it says inside some brackets that are none changeable, 4096×2160@59.94Hz
    Huh. Must be some sort of SMPTE limit?
  • Tom Sefton
    February 19, 2020 at 10:20 pm
    I really don’t know.
  • Oliver Peters
    February 25, 2020 at 4:52 pm
    FYI – Apple’s white paper for the XDR Pro Display.
    https://www.apple.com/pro-display-xdr/pdf/Pro_Display_White_Paper_Feb_2020.pdf
    – Oliver
    Oliver Peters – oliverpeters.com
