Activity Forums Adobe After Effects FCPX Multiclip question
  • FCPX Multiclip question
    Posted by Chad Smith on December 9, 2013 at 5:14 pm
    Using Pluraleyes 3.3 I drag in ProRes footage from camera 1 and camera 2 and my audio mix. Sync everything up and send the XML to FCPX. Once in FCPX it I double click the multiclip it shows the clips synced and the audio mix plays back in sync. I then shut off the audio from the clips and turn on the audio mix track. If I try and play down the multiclip in the event window it does not play or sometimes plays with no audio. If I edit the multiclip into a new timeline to begin editing it does not have audio. I have made sure that I am editing “all” into the timeline. Is this the proper workflow?
    Chad Smith replied 12 years, 9 months ago 1 Member · 1 Reply
  • Chad Smith
    December 9, 2013 at 9:21 pm
    Got it working if I drag the multi clip into the timeline. Would not work cutting into the timeline for some reason.
