FCPX Library file size
Hi
I hope someone can help! I’m on a Macbook Air 2015 256Gb using FCP X 10.1.3 with libraries being stored on a 1Tb external hard drive. The system works fine, and it isn’t slow or boggy. The problem I have is with library sizes.
I have created a few libraries and imported raw files into them. Most shots taken from a GoPro or a Phantom 3 quadcopter. One library has 28.4 Gb of film clips imported into it, but the FCP library on the external drive is showing 268Gb! The original files imported are MP4 files and I have so far in that specific library created only one project that contains an opening black background, three clips, a title on the opening and a closing solid black.. all with cross fade transitionsThe project is 32 seconds long and contains two FCPX standard audio clips in .caf format.
Why would my libraries be 10x the size of the clips in them? I have tried deleting generated event files but that only saved about 5Gb.
Please help!
Connor
