Activity › Forums › Apple Final Cut Pro › FCPX key frames off by single frame
  • FCPX key frames off by single frame
    Posted by Chad Hembree on August 19, 2013 at 5:51 pm
    I am editing green screen video with animated JPG stills. I’ve never had this problem before but when I click a keyframe in transform, that single keyframe jumps back 1 frame from where I desire it to be. I haven’t found any one else to have encountered this issue. Does anyone know how this could be solved? Thank you
    Nikolas Bäurle replied 13 years, 1 month ago 2 Members · 1 Reply
  • Nikolas Bäurle
    August 19, 2013 at 11:46 pm
    You are adding your keyframes in the viewer, right?
    When you click on the Transform icon you will notice that the skimmer disappears and the playhead turns pinkish, like the scrubber and playhead have become one.
    I don’t really consider it a bug, its due to the fact that you can skim samples.
    Zoom in and click around and you will see that the frame area is sometimes in front or behind the playhead. You can also move the playhead inside the frame area, since you can skim at sample level, but video keyframes are at frame level.
    At times the playhead is right in the middle of the frame area. So if the frame area is on top or before the playhead, the playhead jumps back and the keyframe is set one frame before.
    “Always look on the bright side of life” – Monty Python
