Activity Forums Adobe After Effects FCPX Import XML
  • FCPX Import XML
    Posted by David Edwards on November 5, 2015 at 2:08 am
    So I’ve been able to export successfully and import clips and multicam clips to FCPX on the same machine with the same absolute path. But when trying to export a lot of synced clips for use on another machine with a different file path to media, the import fails and doesn’t allow relinking, with “the item could not be read” error. Is there some kind of setting that a allows export from Plural Eyes that won’t fail if the filepaths aren’t the same on the machine where import happens? Thanks!
    David Edwards replied 10 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
