Activity Forums Apple Final Cut Pro FCPX iMac 27″ full screen mode gets stuck since Mavericks
  • FCPX iMac 27″ full screen mode gets stuck since Mavericks
    Posted by Mark Dobson on November 9, 2013 at 9:01 am
    I’m in the middle of trying to sort out an annoying problem whereby, since installing Mavericks, when I go into full screen mode in FCPX the screen gets stuck, normally one hits escape to go back to original layout, but the only way out is to quit FCPX and then relaunch.
    It’s a strange problem, user specific, because when I access FCPX from a different user account on my computer everything works fine.
    I’ve tried all the old tricks, trashing the preferences, repairing disk permissions, trashing and reinstalling FCPX and then finally contacting Apple support. The guy who is helping me also can’t come up with a solution so I thought I’d see if anyone here might have encountered this problem, and hopefully come up with a solution.
    Mark Dobson replied 12 years, 9 months ago 3 Members · 6 Replies
  • Mark Dobson
    November 9, 2013 at 11:51 am
    Thanks – Yes I do have 2 screens and I have tried disabling – and then disconnected the second screen and the problem still occurs.
    But it all works fine if I open FCPX under a fresh user. Weird – obviously something I’ve got on my active system is conflicting.
  • Steve Connor
    November 9, 2013 at 12:43 pm
    Did you do a clean install of Mavericks? It seems to be solving most problems with it.
    Steve Connor
    There’s nothing we can’t argue about on the FCPX COW Forum
  • Mark Dobson
    November 9, 2013 at 2:00 pm
    No I haven’t done a clean install.
    Seems a very extreme step because presumably one has to remove / backup every thing off the drive first?
  • Babylon Slim
    November 10, 2013 at 6:10 am
    After Mavericks, I too was having “buggy” display issues. I searched for an answer at Apple. Found a suggestion to do a PRAM reset. It worked for me. I’d try that 1st b4 going thru the whole clean reinstall/time machine thing – also since it isn’t doing “it” when using an alias, have you repaired disk & permissions. I had to do that twice so far. Otherwise I’m reeling like a Zebco.
    Good Luck
  • Mark Dobson
    November 10, 2013 at 6:22 am
    Thanks Andy
  • Mark Dobson
    November 11, 2013 at 6:20 am
    Thanks Phillip,
    I’d forgotten about resetting the PRAM, it didn’t fix my issue but it was fun remembering how to do it!
    It just seems overkill to reinstall, reformat an entire disk, just to resolve one small problem. But unfortunately the deep skilled knowledge base is slowly disappearing, similar to auto mechanics where one replaces an ECU to fix a faulty bulb.
    I’ll wait to see what Apple technical support comes up with before doing anything drastic.
