Activity Forums Apple Final Cut Pro FCPX Frame Rate Issue
  • FCPX Frame Rate Issue
    Posted by Marc D’amour on April 20, 2012 at 5:11 pm
    Hello all…
    I’m experiencing an issue in FCPX [I’m running 10.0.4 but it’s been present in all versions of FCPX] where the frame rate displayed of the footage I’m bringing in doesn’t match the frame rate displayed in multiple players such as VLC, MPlayerX, and even Quicktime previous to import.
    Here is the scoop:
    I cut sizzle reels for acting clients who want their scenes from TV and Movies cut together in an entertaining fashion. I typically use DVD and BluRay discs as source footage. If I open my files (typically .m4v) before ingesting (and after for that matter) them in FCPX, the correct frame rate (most often 23.976) appears in the info panel. However, once I import these same files into FCPX, the Frame Rate displayed is terribly inconsistent and off. For example, I bring in a clip at 23.976 (in QT) and it displays 24.15 in FCPX. Many movies show up in different frame rates (meaning if I import a bunch of 23.976 clips they are all displayed with DIFFERENT non conforming frame rates).
    I constrain my storylines to 23.976 as that is the output frame rate I desire, but some shots look less than stellar (slightly jittery or choppy) on output and I can’t help but think it’s a frame rate issue.
    I was wondering if anyone else has had this problem, and if so if anyone has a workaround? Also I was wondering if anyone had a great quality solution for transferring 29.97 footage to working in a 23.976 timeline. I know that FCPX lets you work with footage of all different frame rates, but I think it’s a less than ideal solution. I currently use Compressor to shift my stuff from 29.97 to 23.976.
    Thanks to everyone in advance.
    Marc D’amour replied 14 years, 3 months ago 2 Members · 6 Replies
  • Darren Roark
    April 20, 2012 at 11:03 pm
    The jittery and less than stellar motion you are seeing is due to some of your source material is at 29.97. If you have footage that was shot 23.98 with a pulldown, adding that 29.97 footage to a 23.98 will remove frames every second you would normally want.
    Hopefully that explains it. In other words, stick to 29.97 if you have anything with that frame rate. It will look the same on a dvd but without the stuttery video.
    I would invest in Cinematize for ripping clips off of dvds. It’s really simple to use and converts directly to prores at proper framrates. It even makes files with the correct aspect ratio automatically.
    I found this here:
    https://help.apple.com/finalcutpro/mac/10.0.4/
  • Marc D’amour
    April 24, 2012 at 10:25 pm
    Darren,
    Thanks for the reply.
    So in your experience transcoding stuff that originates in 23.976 to 29.97… does the transfer that direction not introduce any stuttering motion or jitters in the footage?
    The interesting thing for the purposes of this project is that the all of the 23.976 footage ingested into FCPX is improperly displaying it’s frame rate. I don’t understand “frame rate flags” but my searches to correct this problem produce those search results often. The other very puzzling thing here is that some of the footage that is jittery in the output string actually originated at 23.976 (after ingesting it displays a crazy 24.15 or something). Although the 29.97 stuff is jittery as well, some 23.976 stuff just doesn’t play smooth.
    I used Cinematize in the past but I don’t think they take .mkv files which is typically the format I have the footage in. I’ll have to check this latest release.
    Thanks very much for the reply.
  • Darren Roark
    April 25, 2012 at 4:47 am
    I think I have a better grip on what’s going on with your issue now.
    You should make yourself familiar with codecs and container files. Anything you bring into a NLE should have been transcoded to something that has a proper framerate cadence. Final Cut Pro X has a way of adjusting framerates of mixed source material but not if they are end user viewing codecs/wrappers.
    That said, what I meant was, you should always work with a project that has the highest framerate of your clips. IE if that is 29.97 then that is what the project should be. In some cases that would actually be 59.97 if for example you were working with HDV 1080i.
    The easiest way to do this in X is, make a project, then put any clip that has the highest frame rate in the project, then you can ad the lesser frame rate clips and FCPX will adjust them automatically.
  • Marc D’amour
    April 28, 2012 at 12:32 am
    Thanks Darren. I appreciate this response. Have you seen any problems with FCPX “improperly reporting” the frame rate of the footage like I mentioned? It sounds like this might be a bug unrelated to my problem and based on what you have reported, not what is causing the stuttering or jittery motion in my output.
  • Marc D’amour
    June 3, 2012 at 6:54 pm
    One real quick followup here… so if I have all my clips and many are 23.976 but a handful are 29.97… I should drop the 29.97 to have FCPX create the timeline settings based on that clip and then subsequently add the 23.976 files. That is clear. Will I encounter problems with stuttering or jittery footage though if FCPX is converting all those 23.976 frame rate files to conform to the timeline setting of 29.97?
    I appreciate your help!
  • Marc D’amour
    June 3, 2012 at 6:56 pm
    Or should I convert everything in a program like Handbrake. Right now I’m using Handbrake to convert the MKV files I take from the source DVD to M4V files for use in FCPX. I have the option in Handbrake to change the Framerate (if the source is 23.976 I can make it 29.97 in Handbrake) or is my best plan to use FCPX to handle the conversion from 23.976 to 29.97.
    Again… thanks!
