Activity Forums Apple Final Cut Pro FCPX export to Apple ProRes 422 (HQ) and LPCM Audio
  • FCPX export to Apple ProRes 422 (HQ) and LPCM Audio
    Posted by Marlo Casabar on December 15, 2011 at 10:35 pm
    Hi Everyone,
    I am using Final Cut Pro 10.0.2, Compressor 4 and OSX Lion 10.7.2
    I have created a 4 minute music video for a client. He needs me to create a special file to be uploaded to Tunecore.
    According to Tunecore, the video must be in the following format
    Codec: Apple Prores 422(HQ) Linear PCM Audio Big or Little Indian, 16 or 24 bit, 48 Khz
    So, I fired up FCProX. Then selected Share – Send to Compressor. I selected the Apple Prores 422. I then changed the audio to LPCM 26 bit 48Khz.
    The final file was 2.59 Gb and when I pulled up the information it showed:
    Codecs: Apple ProRes 422(HQ), Linear PCM, Timecode
    I uploaded the file to Tunecore and they emailed that the file was the wrong format. In fact, they sent me a screen capture of the file information and it showed the file was H.264 AAC.
    This really confused me. How could they show such different information for the same file?
    So I tried another method. I fired up FCProX. Selected Share – Export Using Compressor Settings
    I selected the custom setting I created and started the export. A few minutes later, I got a HUGE file that was 38.12 Gb in size. Under the Codecs it listed
    Component Y’CbCr 10-bit 4:2:2, Linear PCM, Timecode
    Wow…that the file is 16 times larger and doesn’t even show the correct codec!
    So, I rendered another file. I fired up FCProX. Selected Share – Export Using Compressor Settings. This time, I selected the native Apple ProRes 422(HQ).
    This file is 5.88 Gb and shows the following Codecs
    So … which file is correct? Any ideas?
    Marlo
    Tom Wolsky replied 14 years, 9 months ago 2 Members · 1 Reply
  • Tom Wolsky
    December 15, 2011 at 11:41 pm
    If you’re sure the file was correct, open the exported file in the QT player and look at the movie inspector. That will tell you which is the correct file.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
