Activity Forums Apple Final Cut Pro FCPX Export
  • FCPX Export
    Posted by Anthony Winson on August 5, 2012 at 9:01 pm
    I was wondering if anyone could help.
    I’ve rendered my project and added effect ect. Now I need to export my project and then reimport to continue adding effects over the top, I know a lot of people will be wondering why but there is a reason for this haha. How should I export this so that when I reimport it and export it again I won’t lose any quality?
    Many Thanks.
    Ant
    http://www.mrstitchfilms.co.uk
    Anthony Winson replied 14 years, 1 month ago 3 Members · 3 Replies
  • James Cude
    August 5, 2012 at 10:39 pm
    Yes you will be losing quality. Use a Compound Clip instead which does the same thing effectively but doesn’t cost a generation.
  • Olof Ekbergh
    August 6, 2012 at 12:13 pm
    If you export using compressor you can choose a very high quality export, like ProRes4444.
    Most likely ProResHQ422 is all you need.
    I am not sure why you need to do this but I would try the compressor route. I do this if I have something I want to work on in AE or Color. But always before adding graphics.
    Olof Ekbergh
  • Anthony Winson
    August 7, 2012 at 8:24 pm
    Many Thanks. Really appreciate your responses 😀
