Activity › Forums › Apple Final Cut Pro › FCPX error message
  • FCPX error message
    Posted by Ben Lithman on February 25, 2014 at 10:40 am
    I’ve just purchased a NMP and have done a clean install or FCPX. I keep getting the following message…
    “The application detected an error that prevents changes from being saved. To avoid losing your work, quit Final Cut Pro”
    I’ve repaired disk permissions, but the error continues.
    Any ideas how to solve this would be appreciated!
    Tom Brooks replied 12 years, 7 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    February 25, 2014 at 5:24 pm
    What version of FCPX are you using?
    Where is the library?
  • Ben Lithman
    February 25, 2014 at 5:26 pm
    it’s FCPX 10.1.1
    And the Library is on an external Thunderbolt RAID drive.
    Thanks…
  • Jeremy Garchow
    February 25, 2014 at 6:18 pm
    Make sure your permissions are correctly set on the external drive (or whatever folder your library is in).
    The easiest way is to simply ignore ownership on the external drive in the “Get Info” window.
  • Ben Lithman
    February 26, 2014 at 9:39 am
    Hi Jeremy,
    Thanks for your help. I checked and the “ignore ownership” option in the get info window is already ticked.
    Any other suggestions would be appreciated.
    Ben
  • Tom Brooks
    March 2, 2014 at 12:38 pm
