Activity › Forums › Apple Final Cut Pro › FCPX DVD or Compressor DVD export?
Posted by Brandon Adam on December 31, 2014 at 9:15 amHello,
Is there any difference in quality between FCPX and Compressor for DVD export?
SD export.
Thank you.
Robin S. kurz replied 11 years, 8 months ago 3 Members · 2 Replies -
Noah Kadner
December 31, 2014 at 3:19 pmYes depending on the settings you choose in Compressor you could achieve a better looking encode. But it’s still going to be highly compressed 720×480 in any case.
Noah
FCPWORKS – FCPX Workflow
Call Box Training -
Robin S. kurz
January 7, 2015 at 5:49 pmIMHO, even if you theoretically could achieve a technically (not objectively i.e. visually) higher quality version of a clip through Compressor, I highly doubt the task of endlessly fiddling with GOP structure, P-frames et al to get there is worth the minute difference in the end. The encoder is the exact same in both cases and delivers very acceptable (if not by today’s standards 😉 ) results either way.
Using the standard settings (i.e. without fiddling) in either would give the same results from what I’ve (unscientifically) tested.
– RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
