Activity Forums Apple Final Cut Pro FCPX deinterlacing not working correctly
  • FCPX deinterlacing not working correctly
    Posted by Flo De haan on September 28, 2015 at 12:47 pm
    Hello,
    I’m sure it has been asked a thousand times before, but for me the answers I’ve found aren’t working. I hope someone who has a lot of experience here can tell me easily how I do it right:
    I want to deinterlace footage in FCPX.
    – I have an MXF that is interlaced.
    – I create a project and put the clip there.
    – I Click the clip, and go to settings – info (on the right panel) and put it on ‘field dominance override = progressive’
    Now, when I play my clip I don’t see interlacing at all.
    In this case I select a part of my video and make a compound clip.
    I see this clip is 25p in the settings panel and it shows a blurry lines where interlacing should be visible if it were 25i.
    – To this compound clip I even insert a progressive clip
    – Now when I export this compound clip. the result is this:
    I know I’m doing something wrong here, but I cannot figure out what. I was used to adding a simple deinterlace filter in FCP7, but I’m sure I can fix it this way in FCPX as well.
    I also switched view, but that doesn’t change anything.
    Can anyone please tell me what I should adjust in my method to have a nice progressive result?
    Thanks a lot
    Flo De haan replied 10 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    September 28, 2015 at 3:45 pm
    No, you keep the field dominance setting as upper field (assuming HD), and then you need to click the “deinterlace” box in the inspector. It should be under the “settings” layout.
  • Doug Metz
    September 28, 2015 at 3:50 pm
    Two things I would check / try:
    – Select the project in the browser, and check it’s settings in the inspector. Set to Progressive.
    – Instead of overriding the field settings on the clip, select the Deinterlace checkbox in the inspector.
    The combination of these two should get you the results you’re after.
    Doug Metz
    Anode
  • Flo De haan
    September 30, 2015 at 11:35 am
    I’m working with 10.1.1 (I cannot upgrade my OSX due to other programs running)
    Is this supported in this version?
  • Jeremy Garchow
    September 30, 2015 at 12:19 pm
    I think the deinterlace option has been there since the very beginning.
    You should be OK. You might have to edit the metadata view to reveal the option, but I think it should be under the “Extended” or “Settings” option.
  • Flo De haan
    September 30, 2015 at 12:34 pm
    Thanks I found it, and it works!. I have never seen that option before, otherwise of cours I would have clicked it.
  • Jeremy Garchow
    September 30, 2015 at 1:19 pm
    Cool. Glad you’re up and running.
    Remember, this is a global setting, so every where that clip appears, it will be deinterlaced. This is fine if you need progressive output all of the time, but it’s less fine if you need both a progressive and interlaced output. You will have to remember to uncheck the deinterlace button on those clips of you need an interlaced Project.
    Make sense?
    Jeremy
  • Flo De haan
    September 30, 2015 at 1:26 pm
    Thanks.
    I need progressive all the time, so…
