Activity Forums Apple Final Cut Pro FCPX Crashing
  • FCPX Crashing
    Posted by Anthony Winson on August 9, 2012 at 11:25 am
    Hey everyone,
    I’d really appreciate some help I’m so fed up at the moment.
    I’ve got a project which I’ve been working months on and finally finished it and want to export but no matter what I do it crashes. Trying to export from FCPX itself it closes and states FCP quit unexpectedly and if I try through compressor that just comes back as failed.
    At first I kept having problems with rendering and it constantly kept crashing or freezing by computer and bring up something like startup memory almost full, but I just reopened FCPX and press render all then it’d render a bit more then crash, I did this until it rendered the whole project.
    Could it be the rendered files are corrupt because of this?
    The files are converted into MPEG-4 and Quicktime files.
    Many Thanks In Advance.
    http://www.mrstitchfilms.co.uk
    Anthony Winson replied 14 years, 1 month ago 2 Members · 2 Replies
  • Loren Risker
    August 9, 2012 at 10:42 pm
    This is odd behavior. I wouldn’t rule out a failing or full hard drive. If I were you I’d verify you have at least 10% of empty space on your disk, and try a repair disk in disk utility.
    OutOfFocus.TV – Original series, music videos, and entertainment for your couch.
  • Anthony Winson
    August 9, 2012 at 10:52 pm
    It’s so strange, I have around 200GB on my hard drive free.
