Activity Forums Apple Final Cut Pro FCPX Choking On .PNG?
  • FCPX Choking On .PNG?
    Posted by Shane Mcgee on January 11, 2012 at 10:50 am
    I made a .png of my logo in illustrator with the 1920×1080 preset and exported it as a png. Brought it in to its own event in final cut and I’m just trying to make a little fade in logo bumper clip with it.
    I put a fade in blur transition on the beginning and a little ken burns effect on it and the computer is in the most load I’ve ever seen it under. You’d think i was rendering out a feature length Pixar film or something!
    Anyone have an answer to this? I can’t even use the app. Its just rendering forever, completely choking on this simple image file with a couple basic effects on it. Cant even preview it or anything.
    15″ MacBook Pro Quad Core i7 2.0GHz
    1TB G-RAID
    Final Cut Pro X
    Canon T2i
    T. Payton replied 14 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Shane Mcgee
    January 11, 2012 at 11:27 am
    I tried a tiff as well. No go. Something like an hour to render out a 10 second clip on a new quad core MacBook Pro.
    I did think up a little work around though. Drop the still in to the timeline and then drag it out to the desired length. Export that clip as ProRes and reimport it to your project. Everything works smooth as butter on it!
    You would think it could take a single still picture and make it look a lot easier than a high res video file…strangeness…
    1TB G-RAID
    Final Cut Pro X
    Canon T2i
  • Tom Wolsky
    January 11, 2012 at 11:36 am
    Is it 8-bit RGB?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Shane Mcgee
    January 11, 2012 at 11:37 pm
    Yes. For some reason, even though i made the image with a 1920×1080 HD Video preset, its being output to something ike 8000×4500….i have no idea why?
    All I’m doing is going to export and selecting png or tiff…
    1TB G-RAID
    Final Cut Pro X
    Canon T2i
  • Brian Mulligan
    January 12, 2012 at 12:08 am
    Make sure you export at SCREEN or 72 dpi form Illustrator.
    Sounds like you exported at 300 dpi, which will increase the 1920×1080 resolution to compensate.
    Brian Mulligan
    Senior Editor – Autodesk Smoke
    WTHR-TV Indianapolis,IN, USA
    Twitter: @bkmeditor
  • Shane Mcgee
    January 12, 2012 at 12:11 am
    Exactly what I just discovered lol… Thanks for the help though!
    1TB G-RAID
    Final Cut Pro X
    Canon T2i
  • T. Payton
    January 12, 2012 at 12:14 am
    Look liked you exported a PNG from illustrator at 300 dpi. That would give you 7398×4517 image, which is causing the trouble. You want to export at 72dpi from the 1080 present in Illustrator.
    See here:
    BTW. FCP X works just dandy with PNG or PSD files.
    T. Payton
    OneCreative, Albuquerque
  • T. Payton
    January 12, 2012 at 12:26 am
    Tom,
    Just did some tests. 8-bit and 16-bit RGB and CMYK PSD files come in just fine into FCP X.
    T. Payton
