Activity › Forums › Apple Final Cut Pro › FCPX & Blackmagic Raw workflows?
Jeremy Garchow replied 6 years, 9 months ago 7 Members · 22 Replies
Jeff Kirkland
December 1, 2019 at 5:56 pmIt happens when I bring the fcpxml back in from Final Cut. The XML comes in, I then tell Resolve to use the braw files instead of the ProRes files I sent to FCPX but a lot of the braw files end up only having their original embedded audio, not the synced connected audio.
It’s more a Resolve issue than an FCPX one so I’ve started chasing it up that end. I’ll play with it some more once this current edit is over. I’m pretty much working with .braw files 100% of the time now so it’d be great to start next year with a solid workflow for edition them in FCPX.
Jeff Kirkland | Video Producer & Cinematographer
Hobart, Tasmania | Twitter: @jeffkirkland -
Jeremy Garchow
December 2, 2019 at 3:36 amHave you tried exporting a regular XML and translating with SendtoX instead?
Or the other way around, use XtoCC to translate to XML?
