Activity › Forums › Apple Final Cut Pro › FCPX bitches over Modified Files, and will not relink!
  • FCPX bitches over Modified Files, and will not relink!
    Posted by Morten on April 19, 2013 at 1:12 pm
    I have not modified any files, but did export an XML, converted via XMLto7 and opened in PremierePro CS6 just to see if I was able to transfer a project. Now FCPX will not relink to some of the files!
    If this issue is for real, I cannot use FCPX in my professional work!
    – No Parking Production –
    2 x Finalcut Studio3, 2 x Prod. bundle CS6, 2 x MacPro, 2 x ioHD, Ethernet File Server w. X-Raid…. and FCPX on trial
    Morten replied 13 years, 5 months ago 4 Members · 12 Replies
  • 12 Replies
  • Jari Innanen
    April 19, 2013 at 1:29 pm
    You should turn off the “Write XMP ID to Files” on import prefs in PPro.
    More on this thread:
    https://forums.creativecow.net/thread/344/19057#19058
  • Jeremy Garchow
    April 19, 2013 at 1:55 pm
    QTEdit from Digital Rebellion will remove the XMP info and allow you to relink.
  • Morten
    April 19, 2013 at 2:07 pm
    Thanks, will try it.
    I thought this issue was resolved. Will I have the same error if I edit an original in After Effects?
  • Jeremy Garchow
    April 19, 2013 at 2:41 pm
    Yep.
  • Jeremy Garchow
    By the way, you can turn off the XMP prefs in Pr and Ae.
  • Bret Williams
    April 19, 2013 at 7:43 pm
    Yes. It’s a global setting. Turn it off in either and it’s off for both. The digital rebellion fixed it for me. 5 files at a time in the free trial.
  • Morten
    April 19, 2013 at 8:16 pm
    Downloaded QT Edit trial, and I can see it does remove Metadata – but files will still not relink!
    Maybe I can reimport from card?
  • Bret Williams
    April 19, 2013 at 9:22 pm
    You sure you removed the meta? I found the interface a little confusing and if I remember it was a two step process. I’m sure you’ll have to quit and relaunch.
  • Morten
    April 21, 2013 at 9:36 am
    I resolved the problem by reimporting. But imagine if I had formatted the card, then I would have had to do most of the edits again. FCPX should allow me to force relink, like legacy used to offer.
  • Morten
    April 21, 2013 at 12:10 pm
    Reimporting from archive has shifted the timing since last edit. This is a major BUG!
