Activity Forums Apple Final Cut Pro FCPX Audio Pan mode issues
  • FCPX Audio Pan mode issues
    Posted by Eron Otcasek on June 13, 2014 at 3:25 pm
    Hi all, any help on this issue…
    It seems that audio in my timeline will only play when I switch the pan mode to default (as opposed to none, which is the default). Many compound clips, projects, and even clips in the browser require me to switch back and forth between pan modes and channel configurations just to be able to hear the audio… Anyone with some insight?
    Eron Otcasek replied 12 years, 2 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    June 13, 2014 at 8:26 pm
    how are you monitoring your audio?
  • Eron Otcasek
    June 13, 2014 at 9:03 pm
    thanks.
    I am using Soundsticks…. But there are no levels moving in the audio pane… so it is not the output.
  • Jeremy Garchow
    June 13, 2014 at 9:05 pm
    Oh, you mean there’s actually no sound coming out at all?
    Is your timeline setup for surround or stereo?
  • Eron Otcasek
    June 13, 2014 at 9:27 pm
    no sound at all…. I can switch the timeline setup to surround or stereo, but it only seems to work if I individually turn all the audio clips within the timeline to the default pan mode (surround) then switch the timeline to surround as well. Which is not what I want.
